#31 (permalink) |
Still laughs at LOL-Cats.
Car: E36 drop.
Bradenton, FL
: 206945710 |
Nothing special now, But I plan on building my suspension before I really get into building the powertrain up.
KYB AGX Struts Tein S-Tech Springs SPL Subframe Bushings SPL Adj, TC Rods Tein Inner & Outer Tie Rods Rear Suspension Techniques Swaybar Rear Ebay Strutbar New OEM Pads & Rotors FTL. |
#33 (permalink) |
15 seconds EXHILARATION
Car: 1991 Nissan 240SX Coupe
Temple Terrace/USF
: 301961453 |
H&R Sport springs (1" drop),
KYB GR-2 shocks, Suspension Techniques rear sway bar, Welded rear control arms (active toe elimination), 1/8" spacers front and rear, Ingalls FastCam front Camber Bolts, 16x8 FD Mazda RX-7 Wheels, 14.4 pounds, Hankook Ventus Z212 R-S2 225/50/ZR16W I want to upgrade to aftermarket rear front control arms because I did the active toe elimination welding poorly and it would give me more tire clearance. I also want to upgrade to some sort of coilover setup. Right now it would be Koni Yellow/Ground Control but I'm hoping there will be a better budget option where the springs and dampers are matched before I'm ready to uprgrade (could be two years). I want camber plates and hopefully some sort of increased caster. The plates Road Race Engineering sells can be ordered with extra caster built-in at a fixed amount. My brakes will be dual piston calipers from the 93+ Eclipse AWDs, stainless lines, stock rotors from Discount Auto, and Porterfield R4-S front and back. |
#35 (permalink) |
Car: A&E CREW - 05' f-250 - 00' mustang gt - 92' mustang lx hatch - 92' mustang lx coupe - 88' mustang
Tampa/miami
: 3201 |
car 92 stang hatch
upr chrome moly k-member and a-arms upr coil over kits upr caster camberplates lakewood 90/10 struts upr adjustable upper and lower control arms upr anti roll bar lakewood 50/50 struts morroso drag springs car gets 1.32 60 fts all day baby |
#37 (permalink) |
Fake Awake
Car: glorified econo-hatch
the land of spells and fairies
: 2147483647 |
'97 240sx SE
Current: -Megan coilovers, 8kg/6kg, shitty 32 way adjustment -Energy Suspension front and rear anti-roll bars -JGS semi-solid motor mounts -SPL Parts poly tranny mount -Greddy front strut tower brace (Cusco OS style) -SPL Parts T/C rods -Moog tie rod ends -300zx 26mm aluminum 4 pot calipers, OE 280mm x 26mm rotors -Axxis Metal Master pads all around -SS brake lines; Speed Bleeders all around -SPL Parts subframe collars -J30 viscous LSD ----- Future/Yet to be Installed- -Swap out Megan coilovers for KYB Adj. struts and Eibach ProKit springs -Swap out JGS mounts and SPL mount for Nismo motor and transmission mounts -Upgrade to Hawk HPS brake pads all around -Tein tie rods and ends; new rack boots -Moog front ball joints -B13 Sentra (91-94) ball joints, used for rears (1mm larger base, but fit fine) -Energy Suspension steering rack bushings -Energy Suspension Master bushing kit (contains the following ![]() --Front and rear sway bar and endlink bushings (only portion of kit I won't be using) --T/C rod bushings (will be swapping out SPL adj. rods for OE rods) --Front lower control arm bushings --Rear lower control arm bushings --Rear upper arm inner bushings --Rear uprght bushings Changed plans to accomodate fun, quality handling while maintaining the civility of a street car. Replacing all multilink bushings will result in a correct alignment devoid of slight imperfections caused by old bushings. Only bushings not to be swapped out are rear differential bushings, which are in good shape, and the subframe bushings, which are using SPL Parts collars on to lock in place (as Nismo units are entirely too expensive and solids not only require alot of work to press in, but would be too harsh). *Note: B13 Sentra ball joints are used on the rear lower control arms because rear ball joints are not available seperate, and require the purchase of a whole new OE RLCA, which retails over $100. Using the 1mm larger Sentra ball joints works perfectly for 1/3 the cost, and there are no issues with using the 1mm larger base (c'mon its 1mm lol). Last edited by dan : 03-18-2007 at 04:54 PM. |
#38 (permalink) |
mad like crazy not angry
Car: ek hatch
sarasota fl
: 819 |
car: 96 civic hatch
eibach pro springs/non-adjustable shocks skunk2 front camber kit e-bay 2-pt front upper strut tower bar (soon to be password jdm 3-pt) password jdm 2-pt rear tower bar beaks subframe reinforcement tanabe ITR rear sway bar (22mm) rear drum to disk conversion Integra GSR front sway bar (24mm) Civic HX wheels 14x6~6.5 (14lbs) sumitumo htr 200 205/60/14 not bouncy great daily ride and turns like its on rails! But, i'll probobly want more! Last edited by madmanmaigret : 03-13-2007 at 03:27 PM. |
#40 (permalink) |
is working on something
Car: Fords
tampa
: 1958438478 |
My cars not done yet but I do have all the suspention...89 Mustang coupe.
14 point cromoly roll cage Steeda cromoly sub frame connectors Front: UPR cromoly K-member&a-arms UPR aluminum caster/camber plates Steeda coilovers QA1 adjustable coilover struts Afco coilover drag springs Rear: Competition Engineering mini tubs Strange coil over conversion UPR anti-roll bar Custom made BMR double adjustable upper control arms Custom made BMR double adjustable lower control arms Moser seperical upper rearend bushings Afco double adjustable coilover shocks Afco coilover 125# drag springs Moser 35 spline narrowed and braced rear, and 325 MT drag radials
#41 (permalink) |
Jeaaaaaaaa
Car: huh?
St. Petersburg FL.
: 165523845 |
Omni-Power Full Coilovers (10k,12k)
Omni-Power LCA's Benen Trunk Brace Benen Rear Tow Hook Spoon Upper F & R Tie bars Spoon Rear Lower Tie Bar Integra GSR Front Brake Conversion Rota J-Mags on Nitto NT450's Not much but I love the ride and the chassis stiffness! |
#42 (permalink) |
I love to choke people.
Car: 02 Acura RSX-T/04 Acura TL A-spec/01 Mitsu Montero
Clearwater
: 99967765 |
2002 RSX
Koni adjustable shocks Neuspeed Race Springs Neuspeed 27mm Front Swaybar Neuspeed Front Swaybar bushings Neuspeed 22mm Rear Swaybar w/subframe support Neuspeed Upper front tiebar Neuspeed Upper rear tiebar Neuspeed Front lower x-brace Ingall's Fast-Cam front and rear camber kits This is all in my garage waiting for me to get the time to install it. |
#45 (permalink) |
** I ♥ Old Skool **
Car: '06 ///AMG Benz C-230K & T3h Old Skool DA9 (Is For Sale)
Lutz/Tampa
: 2147483647 |
The Current '04.5 V-Dub Jetta GLI 1.8T
- Stock GLI 18" BBS RC's w/ Goodyear Eagle F1 225/40-ZR18 tires - BBS Center caps from Tirerack.com - H&R 8mm hubcentric wheel spacers w/ bolts in front - H&R 15mm hubcentric wheel spacers w/ bolts in rear - H&R Race springs - Koni Yellow Adjustable shocks - Neuspeed 25mm front lower swaybar - Black Forest front Lower adjustable endlinks - Neuspeed 28mm rear lower swaybar - Neuspeed rear upper strut tower bar - Neuspeed front upper tie bar - Neuspeed front lower tie bar - EM Racing C-Pillar Bar The Current '04 Honda Accord Sedan - 19" Axis Neo's with Nitto 555 235/35/19" tires - Tein S-Tech springs - (HFP) Honda Factory Performance Shocks - Ingalls Adjustable rear Camber/Toe links - Comptech 22mm Rear lower swaybar. The Old '00 Honda Civic Si Coupe -15” Rota Slipstreams w/ 205/50/15” Falcon zeix tires at 90% life left -Sparco 4pt Harness Bar -Skunk2 2nd gen. Upper A-arm camber kit -Lakewood Titanium Traction Bars (never fully installed) -Korbach Red Frame Locks -Benen Black 3 point upper strut tower bar. -Benen Black Rear Upper Tie Bar -Benen Black Front & Rear lower Tow Hooks (+ 1 extra Rear) -Benen Black Inner Trunk Strong Bar (Road Series) 4 bolt -Benen Black rear Lower tie bar -Benen Black Front Lower Tie Bar -Benen Black 1st Gen. strong bar (custom fitted) -Benen Black Front Lower X-Brace -Silvers JDM Engine Damper (custom fitted) -EM Racing/DRIVE Brake Master Cylinder Brace -Beaks/JDM ITR 23mm rear lower tie bar kit w/ Suspension Tech. Polly D-bushings -Tokico Illumina five-way adjustable shocks w/ Ground Control coilovers -OmniPower rear LCAs The Old '99 Acura Integra JRSCed Ls -16x6.5 Bronze Rota Circuit 8s wrapped in 205/45/16 Yokohama Parada Spec-2s, 70% tread left on tires -Neuspeed Race springs @ 2.5" drop -KYB AGX. Adj. 4 way Shocks -DC Sports rear lower polished tie bar -DC Sports rear upper strut tower bar -Neuspeed front lower tie bar. -Neuspeed front upper 4 point strut tower bar -JDM Do-Luck* polished back seat floor chassis bar -Suspension Techniques 24mm front lower Sway bar w/ Poly. Energy Suspension Red Endlinks and D-bushings -ITR 23mm rear lower sway bar -ITR trunk rear deck frame bar -DIY tubular 1" rear seat delete brace, custom made and installed. -J's Racing Engine Damper -J's Racing C-Pillar Bar
| Sponsored Links |
