#1 (permalink) |
CFP was...
Car: 93 Nissan 240sx with RB25dett, 91 Honda CRX Si with B16.
Lots of parts for sale!!!!! nissan, toyota, honda,etc.
MAKE YOUR OWN OFFER!!!!!!!
Used parts blow out Here at CFP we have accumulated many many parts overs the years and we are running out of room. We add parts to this list every day so keep a check on it. We have a large assortment of different parts such as, NISSAN PARTS!!!!!! Motegi Touge 17x9 +24 offset x2 with 225/45zr17 rt-615 azenis, black with polished lip, $250 Used Megan Racing street coilovers $600 SOLD starters (KA $40) X10 (SR $150)SOLD diffs S13 and S14 $40 EACH 1 used megan racing downpipe $40 1 used hks down pipe. $80 S15 6 speed tranny with flywheel and clutch. $750 2 s14 doors no window motors $35 EACH 2 s14 door mirrors $10 EACH 2 s14 rear seats one Grey the other blue/Grey $15 EACH 1 pair of s14 door panels $15 each S14 spoiler SE $20 S13 rhd dash has some cracks $40 S14 trunk $30 LHD heads up dash $100 S13 hood green good shape $25 S13 SR20DET tranny $250 S13 SR oil pan $25 S13 SR igniter chip $70 RB26 injectors 6 of them $100 barley used sr water pump $25 Sr and ka fan clutches $5 EACH Single cam lip and bumper $40 S13 nismo catback exhaust $150 SOLD SR20DET nismo stage 2 clutch $150 S13 coupe rear glass $20 S14 zenkie front running lights (clear) $15 Z32 igniter chip $40 Passenger side s14 koukie headlight $50 Megan Racing new heat shield for s13 master cylinder $35 EACH LHD s13 radio bezel $ 10 S14 sr coil pack cover cracked but still usable $20 S13 sr used oil pump and case $40 S13 sr coil pack harness $30 S13 sr cam angle sensor $80 S13 sr crank pulley $40 1 new megan racing o2 housing $80 SOLD 1 new megan racing test pipe $60 SOLD 1 sr valve cover(s13) $50 350z head $100 P/S lines Alternators KA $30 Valve covers a/c lines Intakes Side mount intercoolers $20 EACH exhaust headers Intake manifolds Driveshafts Power steering pumps Radiators $40 KA24de and e ecu's $20 Flywheels KA $20 Pressure plates Mass air flow sensors KA24 $25 to Injectors Fuel rails KA24de and e $15 A/C, P/S, ALT, brackets Coil packs SR $25 EACH Tranny mounts KA & SR $30 TC rods S13 stock $5 EACH TC rod brackets $10 EACH 4 lug hubs $5 EACH A lot of brake calipers and brackets Stock suspension Throttle bodies P/S resiviors Electric fans single or twin $50 to $60 (will work on s13 rads) A/C compressors sold as is no refunds on a/c compressors/ca18,sr20,s13 and s14 ka24de/e S13 dust shiled for tranny S13 side mirrors $15 EACH S14 zenkie tailights $30 S14 gauge cluster $40 SE S13/s14 diffs $40 KA24de trannys SOLD Empty s13 rear subframe $40 Distributors 2 gtir pulsar tranny's with tranfer cases $30 EACH HONDA PARTS!!!! D16z6 full swap manual trans. $450 SOLD D15b7 full swap auto trans. $180 B-d series fflywheels B18a ls long block $280 Shift linkages Intake manifolds ECU's VTEC engine harness's Axles Distributors EF gauge cluster with tach Motor mount brackets Motor mounts 1992 jdm 1 piece headlights for prelude $100 B-D series half shafts Valve covers (non vtec) Lowering springs JDM B16A2 ecu (p30) $150 1992 prelude spoiler silver $20 CRX center console $30 Tiburon headers obx used $45 H23 sparco 9mm spark plug wires used $25 1992-96 prelude short shifter kit(new) $30 TOYOTA PARTS!!!!!!!!!!!!!! ct 26 turbo $50 20 valve tranny 5 speed $50 MITSUBISHI PARTS!!!!!!!!!!!! 3000gt vr4 short block (2 bolt main) good shape $200 vr4 tranny 5 speed $100 TIRES!!!!!!!!!!!!!!! We also have a large amout of 16,17 and 18 inch tires forsale So tell us what u need and we will see what we have for you. Call us at Central Florida Performance 727 572 4340, just ask for Ivan, Mikey or me, me being Kevin. Thanks for looking and have a great day. Last edited by CFP_IVAN : 09-13-2007 at 03:42 PM. |
#10 (permalink) |
^I'm with stupid.
Car: 94' LHS,nothing else until done with school.
hood,pignose bumper and lip,coupe rear glass,s13 5spd driveshaft,tc rods and brackets,4lug hubs,s14 guage cluster,and rear empty subframe,considering I had most of that stuff when you got the coupe from me you could atleast hold on to it for me man.I also need twin cam ecu,harness.Just hold on to some things for me man thanks,ill come give you a hand if need be too lmk.
#15 (permalink) |
CFP was...
| Sponsored Links |
