#1 (permalink) |
NY till i die.....
Car: 99 Durango,96 Maxima, need a vh45
the hill...
: 24260651 |
Power Acoutik bd1500 + hx2
buddy of mine just blew one of his hx2s. sellin the rest of the system...
bd1500 - $400 obo the amp does 1642 watts at 13.5 volts not at 14.3 volts most cars push. Class bd technology 750 watts RMS x 1 at 4 ohms 1500 watts x 1 at 2 ohms selectable 50-250 Hz variable low-pass crossover, 24 dB/octave MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability. TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp. NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance. preamp outputs for easy connection to a second amplifier wired remote control of Punch Bass (0-18 dB centered at 45 Hz) subsonic filter removes frequencies below the range of human hearing for increased efficiency dimensions: 18-1/2"W (13-11/16" without endcaps) x 2-7/16"H x 9-7/8"D ![]() 15" power hx2 - $100 obo Dual 3" 4 Layer LXtended 4ohm Voice Coils Coil on Aluminum Former FIBERLock Cone Hyper XTended Pole Piece LXcursion Cast Frame Dual Laminated Progressive Flat Spider BART Surround CONsealer gasket hides mounting screws and provides an airtight seal Aeroport Exhaust Rubber Magnet Boot Frequency response 24-200 Hz RMS power handling: 600 watts RMS (250 watts per voice coil) peak power handling: 1200 watts Sensitivity 89 dB SPL Top mount depth 6-15/16" Sealed box volume 2.25-5.0 cubic feet Ported box volume 2.0-4.0 cubic feet Impedance 4 ohms Peak Power Handling 1200 watts RMS Power Handling 600 watts Woofer Surround Santoprene Rubber Woofer Composition N/A Sealed Box Volume 2.25 - 5.0 cubic feet Ported Box Volume 2.0 - 4.0 cubic feet Sensitivity 89 dB Frequency Response 24 - 200 Hz Xmax (millimeters) N/A Top Mount Depth 6-15/16" Cutout Diameter 13-7/8" ![]() lmk.. Last edited by Nycist : 06-23-2007 at 07:45 PM. |
#4 (permalink) |
NY till i die.....
the hill...
: 24260651 |
word....
some ppl are just too lazy to do their own research.. system was so powerfull that it snapped every screw that was holding both speakers in the box.... Last edited by Nycist : 06-23-2007 at 07:47 PM. |
#5 (permalink) |
Datsun Driver
Car: 1985 Nissan 300 XXX, 1975 Datsun 240
Hellview, FL
: 53211 |
actually i was too lazy to read your whole post. i didnt see hx-2. and your original title said "power acoustik 1500 bd). had i known it was a RF bd series, i would have been all over it. open to trades?
#8 (permalink) |
Datsun Driver
Hellview, FL
: 53211 |
literally 2 month old Power Acoustik LT1440/2, in box.its in perfect cond, missing nothing, etc. but it doesnt have the power the BD does. The only nice thing about my PA is it is like brand new. ask him how much money he would want on top.
#15 (permalink) |
NY till i die.....
the hill...
: 24260651 |
tt
| Sponsored Links |
