Fuel Injector Service Pricing
Complete Fuel Injector Cleaning & Flow Testing
Process:
* Outboard
* Marine (HPDI, Optimax, etc.)
* Automotive
* High Performance Automotive (Up to 4000cc injectors! No injector too big!)
* Motorcycles
* ATVs
This is the current list of side-feed injectors we can do:
Process:
- Injectors bodies are cleaned, visual inspected, and numbered.
- Injector coils are now tested for resistance, shorts, and current draw.
- Perform leak test, spray pattern, and flow rate testing on our ASNU flow bench. Record the results.
- Remove filter baskets, o-rings, and pintle caps. Bead-blast any loose paint and rust from the metal injector body.
- The injectors are placed in our first ultrasonic cleaning tank to remove and any particles, dirt, etc for 5-10 minutes.
- Into a second ultrasonic tank they go, they are now cycled on and off allowing the ultrasonic energy to dislodge any particles and build-up inside the injectors for 15-20 minutes.
- A high pressure back-flush is done to remove any particles inside.
- Install new filter baskets, o-rings, and pintle caps. (as required)
- Back to the flow bench for retesting of spray pattern, flow rate, and leak checking. This test data is also recorded
- (If requested) Prepare a comprehensive test report with before and after test data.
- Top Feed - $20.00/each
- Top Feed (Hose Fed) - $25.00/each
- Side Feed - $25.00/each
- Optimax w/ Air Injector - $35.00/each
- GM Vortec V6 "Spider" - $160.00/6 injectors
- GM Vortec V8 "Spider" - $190.00/8 injectors
- All Injectors - $10.00/each
- DIY Injector Rebuild Kits starting at $20.00
* Outboard
* Automotive
* Motorcycles
* ATVs
- Rochester/Delphi (Volkswagen, GM TBI, etc.)
- Nippondenso (Jaguar, Chrysler 3.5, Ford, etc.)
- Bosch JECS (Nissan/Toyota) (
- JECS (Nissan/Subaru) (STI, Maxima, etc.)
- JECS (Toyota) (Supra, MR2, etc.)
- GM Vortec 4.3L (1992-1995)
- GM Vortec 4.3L and 5.7L CPI
BOOST LAB, INC.
95 Toyota Supra Turbo - 1000HP
http://www.TheBoostLab.com
TURBO SERVICING & SALES | FUEL INJECTOR SERVICING
GARRETT - BORGWARNER - BULLSEYE - HOLSET - 3K
TiAL - TURBONETICS - FULLRACE - PRECISION
Shop Forum | FaceBook | Website | Online Store
BOOST LAB, INC.
