+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Installs & Fixes Anything senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute
    Join Date
    May 2005
    Location
    around Tampa Florida, Paradise
    Posts
    6,425
    Blog Entries
    Feedback Score
    19 (100%)
    Aftermarket Springs vs Modified Springs (I Do Both)
    Originally Posted by senor honda
    In addition to installing aftermarket springs for people, I also lower cars by
    precisely measuring and cutting stock springs. Based on this experience, 1.5" works well as a street lowering for cars I have worked on. More than 1.5" requires a camber kit for most cars , or the negative camber eats up the tires.
    I find that good shocks keep a car from bottoming, and stiff springs cause a car to lose grip in the turns, a lot of times because the stiffness causes the car/tires to bounce around, instead of following the road contours. Negative camber on some cars will cause reduced grip due to less tire contact in the turns.
    If you are planning to really slam the car down, you might have to get both adjustable-height shocks and springs from the same manufacturer. When some MFG's claim "X" amount of lowering, it can only be achieved by using THEIR spring/shock combination.
    There are several things to be measured *in addition to* tire/wheel well clearance. A spring that's too short for your particular suspension is
    too short whether you paid $300 for it, or made it too short all by yourself........................something that not everyone on this site understands.
    And a spring that's too short, no matter how you got it too short, is what flops around loose, eats tires, and beats up your suspension.
    Some people have me precisely measure and cut their stock springs while they are saving up for expensive aftermarket springs, and I am the only person I know who is able to precisely measure, to avoid the above problems.
    My reply is based on my experiences, and not internet "research"
    of crappy car repairs. If you want to verify that all I say is true, you can ride with me sometime.-Bob
    ---- on-site *Aftermarket* spring/suspension installations --- on-site impact wrenching---street lowering with your own stock springs...........
    Much more at Bob's Garage!
    http://www.tamparacing.com/forums/bo...ontact-us.html
    Have a great day! bobfixesitup@yahoo.com 813-839-4281 (24 hrs)
  2. #2
    Registered User jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute jdmem205 has a reputation beyond repute
    Join Date
    May 2008
    Posts
    656
    Feedback Score
    1 (100%)
    So you can cut my stock springs on my 98 hatch?
  3. #3
    Join Date
    May 2005
    Location
    Posts
    6,425
    Blog Entries
    Feedback Score
    19 (100%)
    There are about 6 types of springs, and not knowing which type are on your car, I will have to look at the springs and take a few measurements.
    I am the only person I know who is able to precisely measure, to avoid problems.
    If everything checks out, I can lower the car. If not, then I will be up front and tell you so. I have never messed up anyone's car, and I don't plan to start now.-Bob
    Quote Originally Posted by jdmem205 View Post
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
