Skunk2’s 1990-93 Integra Front Camber Kit
Electromotive Tuner
on
Pro Series Adjustable Front Camber Kits; 1990-93 Integra
Part #: 516-05-5650
Skunk2 designed its Pro Series Front Camber Kit for the ’90-’93 Integra with specially engineered A-arms and ball joints that allow for maximum positive camber adjustment in a low-profile design. Enthusiasts who are serious about performance can now correct almost all abnormal tire wear due to negative camber and increase high-speed stability.
Each Pro Series Camber Kit includes Skunk2’s all-new, one-piece, forged Pro Series Ball Joints, which feature low-profile top plates for additional clearance between themselves and the shock towers, higher clamping loads for no-slip performance, and a unique design that allows for maximum adjustability. Skunk2 ‘s cadmium-plated, Pro Series Ball Joints can also be adjusted from the bottom up, which allows for quicker and easier adjustments—especially on lowered vehicles with shortened shock bodies. In addition to improved ride characteristics and reduced tire wear on lowered vehicles, Skunk2's proprietary design helps reduce structural fatigue and failure commonly associated with other camber adjustment kits.
www.BivcoPerformance.com
Specialize parts, Tuning and Tinting Specialist
813-380-7027
813-380-7027
