Why you should balance your own motorcycle tires
Old 04-12-2017, 12:45 PM
Default Why you should balance your own motorcycle tires
https://www.youtube.com/watch?v=vkO_LCEdknU
The rear drive assembly on a Harley Davidson is made of several rotating components, The brake rotor, the compensator sprocket, the bowl with rubber inserts, the rim and tire. By individually balancing each component during assembly and matching heavy side with light sides, fewer weights are needed. Most spin balance are not capable of mounting the sprocket and it is therefore not balance. As shown, the sprocket can be considerably out of balance. This video will show why it is important to balance the entire rotating assembly.
Chassis & Suspension Tech
21
08-14-2007 03:18 PM
Angry Pirate
09-21-2006 02:19 PM
nismo180
Nissan/Infiniti Tech
14
07-31-2003 07:56 AM
The Kyle
06-11-2002 12:02 PM
Quick Reply: Why you should balance your own motorcycle tires
