+ Reply to Thread
Results 1 to 9 of 9
Thread: dirty pilot jets(help)
02-10-2012 07:09 PM #1save the s.o.h.c
- Join Date
- Jul 2004
- Location
- tampa
- Posts
- 3,173
- Feedback Score
- 32 (97%)
i just bought a 01 zx9 that has been sitting for awhile. bottom end is slugish but clears out at about 4-5k i assume that this from dirty jet specifically the pilots. anyone know a reputable shop to clean and sync my carbs or if anyone here can do this pm contact info and price. thanks
02-10-2012 07:54 PM #2Registered User
- Join Date
- Jul 2003
- Location
- Santa Fe, New Mexico
- Posts
- 299
- Feedback Score
- 0
Before you spend the money, try some Seafoam. I've used it on bikes that have sat a very long time with great results.
Use it a couple times a year and you'll be good to go.10 BMW R1200GSA 30th Anniversary
Hondas: 70 z50 Mini Trail, 71 CT Trail 70, 79 CBX, 02 XR650R Plated
Kawasakis: 78 KZ1000 Z1-R, 78 KZ1000A2 Fighter, 81 GPz550, 82 KZ1000 ELR #8, 02 ZRX1200
Suzukis: 86 GSXR1100, 87 GSXR50
Yamahas 75 GT80 Mini Enduro, 81 Seca 550
02-10-2012 08:51 PM #3save the s.o.h.c
- Join Date
- Jul 2004
- Location
- tampa
- Posts
- 3,173
- Feedback Score
- 32 (97%)
i put some in today. 1oz per gallon. only put maybe 20 miles on since hasnt cleared up. hoping it will tho. does it take longer from your experience?
02-10-2012 09:35 PM #4Registered User
- Join Date
- Jul 2003
- Location
- Posts
- 299
- Feedback Score
- 0
Yes.
You can add another half ounce per gallon.
Go find a road where you can ride around on the Pilot. Keep the revs low in top gear and let that Seafoam get to the pilot jet.
If it doesn't work, don't be scared to take them off and do the job yourself. I suggest getting a factory manual and doing everything yourself if you can.
Good luck.10 BMW R1200GSA 30th Anniversary
02-10-2012 11:40 PM #5save the s.o.h.c
- Join Date
- Jul 2004
- Location
- tampa
- Posts
- 3,173
- Feedback Score
- 32 (97%)
ok. thanks.
02-11-2012 12:41 AM #6Registered User
- Join Date
- Mar 2008
- Posts
- 633
- Feedback Score
- 0
Get some carb cleaner, pop open the intake of the carb spray the crap out of it. If that doesnt do anything take out the carb yourself its very easy
02-11-2012 07:29 PM #7save the s.o.h.c
- Join Date
- Jul 2004
- Location
- tampa
- Posts
- 3,173
- Feedback Score
- 32 (97%)
well the seafoam helped a little. but didnt cure it completely. still has a bog until about 3k and bogs really heavy causing to die out with a quick twist of the throttle while idling. from what i have read its likely that the pilot jet is the issue. i have decided i will pull the carbs of tomorrow to clean it out. anyone have any tips. i mechanically incline do all my work on car from swaps tuning and so on. but bikes and CARBS is a new world to me. any tips will be appreciated
thanks
02-12-2012 10:30 AM #8Registered User
- Join Date
- Jul 2003
- Location
- Posts
- 299
- Feedback Score
- 0
Go get some Berrymans from the auto parts store to soak all the parts.
Careful with the gaskets.
Have some small wire to run through the pilot and main jet. Check the needle.
Replace the JIS screws on the bowls and caps with allen heads. If the carbs have never been apart, there's a good chance of stripping screws.
You may need a hair dryer to make the rubber boots pliablle.
Have fun. It should be a piece of cake for you.Last edited by pjb03; 02-12-2012 at 10:35 AM.
02-12-2012 11:04 AM #9save the s.o.h.c
- Join Date
- Jul 2004
- Location
- tampa
- Posts
- 3,173
- Feedback Score
- 32 (97%)
i ended up doing taking them apart last night. i only cleared the pilots out. what a difference. i plan on taking them back off again soon to go threw them completely. they were pretty nasty. bike only has 6k on it but has been sitting for a while since he he laid it down and being in military. whats a ideal warm up temp to start riding.
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
