+ Reply to Thread
Results 1 to 15 of 17
Thread: Amp cuts out?
11-30-2009 11:27 AM #1Ballin Beretta
- Join Date
- Mar 2007
- Location
- Tampa
- Posts
- 1,303
- Feedback Score
- 2 (100%)
Amp cuts out?
I have a '96 Beretta with stock battery, and alternator...my problem is that my amp and/or HU cuts off at a certain volume. I have owned louder systems before so the volume isnt that loud.
I do own a low quality system so that could be one of the reasons.
Alpine HU (i think 9984)
2 12'' Sony X-shits lol
Dual amplifier (also is mounted on a bandpass box)
I am pretty sure that my installation is fine so i dont think thats the issue
thanks
11-30-2009 01:00 PM #2Ballin Beretta
- Join Date
- Mar 2007
- Location
- Tampa
- Posts
- 1,303
- Feedback Score
- 2 (100%)
also when the amp and or HU cuts out it turns right back on...it plays fine when im guessing a "comfortable" volume for the amp lol
11-30-2009 02:44 PM #3
i would guess you are clipping(shorting out) one of the speakers connected to the headunit. have you upgraded them? one might of the leads mght be touching metal when turned up?, or voice coil is shorting out putting head unit into protect and turning off.
11-30-2009 02:58 PM #4Registered User
- Join Date
- Aug 2008
- Location
- Palm Harbor
- Posts
- 513
- Feedback Score
- 1 (100%)
When it 'cuts off' are you just losing the sound or is the unit literally turning off?
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
11-30-2009 11:13 PM #5Ballin Beretta
- Join Date
- Mar 2007
- Location
- Tampa
- Posts
- 1,303
- Feedback Score
- 2 (100%)
11-30-2009 11:15 PM #6Ballin Beretta
- Join Date
- Mar 2007
- Location
- Tampa
- Posts
- 1,303
- Feedback Score
- 2 (100%)
11-30-2009 11:24 PM #7Registered User
- Join Date
- Dec 2007
- Posts
- 1,074
- Feedback Score
- 1 (100%)
so everything electrical shuts off? does the amp get hot?
12-01-2009 10:16 AM #8Registered User
- Join Date
- Aug 2008
- Location
- Palm Harbor
- Posts
- 513
- Feedback Score
- 1 (100%)
Ah, so if the HU is shutting off it's turning the amp off. Pop out your hu and meter the power, make sure you're not getting a massive voltage loss at the HU. Check both the constant and ignition. Then jump a new ground onto a nice solid clean metal surface instead of the harness. Check and be sure none of the pins in the harness have worked their way loose too, I've see that many times.
Luke
Audio Expert
727-573-2626
12-01-2009 05:20 PM #9
Yep, those pins will waste a lot of your time figuring that out, always run a good ground to chasis metal. i would make sure none of the non used speaker leads out of the radio are not touching, bell cap none used wires!
run a temp wire from battery to power radio and see if it still does it - this will rule out power in harness.
12-01-2009 05:40 PM #10
12-02-2009 10:19 AM #11Ballin Beretta
- Join Date
- Mar 2007
- Location
- Tampa
- Posts
- 1,303
- Feedback Score
- 2 (100%)
12-02-2009 10:40 AM #12Registered User
- Join Date
- Jun 2006
- Posts
- 1,576
- Feedback Score
- 4 (100%)
Does the HU cut off or just the sound?
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Image Dynamics XS69s
Amp: Kicker ZX650.4
Sub Stage
Subs: N/A
Amp: N/A
12-02-2009 10:42 AM #13Registered User
- Join Date
- Aug 2008
- Location
- Palm Harbor
- Posts
- 513
- Feedback Score
- 1 (100%)
The pins in the wiring harness. Even a cheapo wal-mart meter will do the job.
Luke
Audio Expert
727-573-2626
12-02-2009 04:23 PM #14Resident Ginger Kid...
- Join Date
- Jul 2006
- Location
- Norf Carolina
- Posts
- 3,470
- Feedback Score
- 1 (100%)
monitor your voltage... It may be dropping low enough to make the headunit and amp turn off...
2005 Joe Gibbs Silverado # 0396
2004 Mustang GT 40th anniversary
87 Chevy K10
2-75 Camaro's ( yea they be race em cars )
12-02-2009 08:48 PM #15
exactly. my alpine does the exact same thing. i think they have built in voltage drop protectors...when its idling and i have it turned up, the alt cant keep up and my battery sucks cause its cheapo 3 year old advance auto batt. but it will shut down the head unit, in turn shutting off the amps....upgrade your alt and battery.
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
