My amp turns on but my subwoofer doesn't???
Old 09-19-2009, 09:33 AM
The_Answer's Avatar
Default My amp turns on but my subwoofer doesn't???
Like my title states, I'm having some trouble with my subwoofer.
I have an Alpine Type R 12", and Alpine amp and an Alpine headunit.
The story:
My subwoofer was working fine on Wednesday then I took it in to get 2 new tires so I took the subwoofer out. I put it back in the next morning, and now it doesn't work. However the amp turns on. I checked the wiring to the amp and to the sub. Everything looked as it did before. I'm not too sure what is wrong. Any suggestions will help! Thanks ahead of time!
Old 09-19-2009, 10:33 AM
Taco15's Avatar
check your RCA's and remote wire.
do hear anything coming out of the speaker when the amp turns on?
Old 09-19-2009, 10:57 AM
The_Answer's Avatar
I don't hear anything, it's completely silent. I checked the wires and they seem to be fine.
Old 09-21-2009, 04:41 AM
luke81's Avatar
When you removed the woofer did you pull the fuse from the amp? If you left it on, is there any chance the speaker wire touched each other and shorted?
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old 09-21-2009, 08:14 AM
On The Paper Chase
HaViKTypeR's Avatar
^^^Yea im thinkin u shorted the amp bro, if all wires and connections are fine try connecting another sub just to check and u'll kno if its the amp or the subs........
Old 09-21-2009, 04:33 PM
The_Answer's Avatar
Thanks for the replies guys! I didn't remove the fuses when I took the sub out. I hooked up another speaker and it didn't work either. I changed all the fuses yesterday and still nothing(2 on the amp, one for the power supply). If it shorted out, how do I go about fixing it, or am I screwed and have to buy another sub?
Old 09-21-2009, 06:06 PM
Taco15's Avatar
install another amp and see what happens. You very well could have shorted the remote wire or something.
go take it to an audio shop and have them test it.
Old 09-21-2009, 06:47 PM
The_Answer's Avatar
I will be doing that next week, I'm going out of town this weekend and don't really have the time. Thanks for the help!
Old 10-01-2009, 09:13 AM
The_Answer's Avatar
Took it to divine sound. They said they tested everything and they also said my subwoofer wasn't plugged in inside the box...but I KNOW it was. They told me I fried the outputs from my amp, but wouldn't the fuse go first? They were done in 10 min checking so I highly doubt they tested the wires. I would have talked to them more but I was at work when they checked. Any other help??????
Old 10-01-2009, 09:19 AM
Bob
EclipseGT01's Avatar
Not really. If you are running a 2 channel amp, and running two 4 ohm subwoofers running parallel, and then bridging it, you are then running the amp at 2 ohms rather than 4 ohms where it is stable bridged, and you can blow a channel. Did you have a 2-channel or a mono block?
2005 Subaru Impreza WRX
Slowboy Racing, Perrin Performance, Cobb Tuning, Invidia, Subaru Tenica International, and eBay !!!
If you need a car stereo install, email me at imsowrxy@gmail.com. I come to you for the install.
