Forums Register TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Audio HQ
Old 05-06-2008, 09:19 AM   #1 (permalink)
Car: 99 silver EM1 sc61 turbo; 2002 lincoln ls-Silver
tampa
20whiteboy03 will become famous soon enough: 76303
Line output in 2006 honda civic help?
I{ was trying to put a line output converter in my g/f 2006 honda civic and i tapped into the stock sub but it will not send a signal from the line output to the amp wtf.
20whiteboy03 is offline
Old 05-06-2008, 02:23 PM   #2 (permalink)
hell yeah son
Car: Wrangler, ZX6
Tampa
TBSpyder has a reputation beyond repute: 28649711
The signal may not be strong enough. Try tapping into a full range speaker instead.
TBSpyder is offline
Old 05-06-2008, 10:02 PM   #3 (permalink)
motorboat captain
Car: '99 GS300, e30 325iC
plant city / tampa
jriggs has a reputation beyond repute: 397906314
sub might be a 'duel voice' sub or have some crazy wiring my gs did. try using one lead as a + and then ground the - and see if you get a signal. its what i did to make my line out work
jriggs is offline
Old 05-13-2008, 03:18 PM   #4 (permalink)
S1 member
Car: 90 mazda rx7
tampa
nofxareforkids has a reputation beyond repute: 6655351
also check your line output converter a lot of them are manufactured like crap and some just don't work. when i worked for circuit city we had entire shipments of em be bad
nofxareforkids is offline
Old 05-15-2008, 07:27 AM   #5 (permalink)
Car:
MCOR has a reputation beyond repute: 23957206
A passive line output convertor (Hi/Lo Convertor with no power/ground connections) does not work really well at getting a useable signal from the sub speaker wires. You are better off tapping the right rear and left rear speaker wires to get signal to the convertor. You will get a cleaner full range signal and it is usually a little more adjustable than using sub amp output wires.
MCOR is offline
Sponsored Links
