Forums Register TRHelp TRGarage TRader Ratings Classifieds Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Audio HQ
Old 05-03-2008, 01:39 PM   #1 (permalink)
Car: Chevy Cavalier
Seminole
CAVALIER96 has a reputation beyond repute: 5449118
question about subs
I wanna get 2 10" Kicker CompVR's and they have an option of dual 2-ohm or dual 4-ohm voice coils. What is the difference they are both the same price
CAVALIER96 is offline
Old 05-03-2008, 03:12 PM   #2 (permalink)
hell yeah son
Car: Wrangler, ZX6
Tampa
TBSpyder has a reputation beyond repute: 28649711
No difference other than wiring options. Depends on what amp you go with and what it's stable to, as well as what kind of power you're trying to get out of it. Do you have an amp yet?
TBSpyder is offline
Old 05-03-2008, 03:55 PM   #3 (permalink)
Car: Chevy Cavalier
Seminole
Yeah I have a 2 channel 1000 watt sony xplod amp right now
Old 05-03-2008, 04:35 PM   #4 (permalink)
hell yeah son
Car: Wrangler, ZX6
Tampa
Assuming it's the amp I found online (XM-1652Z), your best bet is to get the dual 4-ohm subs, wire each sub individually in parrallel and then put one on each channel of the amp. That amp appears to only put out 200w rms at that as well (and with Sony, that is probably even overrated) so you definetly might want to consider a bigger amp. Those subs should handle a true 400w rms each without a problem
TBSpyder is offline
Old 05-03-2008, 09:29 PM   #5 (permalink)
is a street vacuum
Car: 2007 MazdaSpeed6
South Tampa, Northdale.
POST has disabled reputation: 550032890
Quote:
Agreed, you guys really need to stop buying that cheap crap Sony puts out. Just because it says 1000w on the box does not mean that's generally what you're going to be using to the subwoofers themselves. Remember that research is key, and to do lots of it before you throw down a couple hundred in equipment.
Dump that Sony off on an older relative paired with a very small subwoofer and make their day while getting yourself something bigger with much better power ratings and quality.
POST is offline
Old 05-04-2008, 12:15 PM   #6 (permalink)
Car: Chevy Cavalier
Seminole
So what would you guys recommend as a replacement that would be the best for the setup I want?
Old 05-05-2008, 01:20 PM   #7 (permalink)
hell yeah son
Car: Wrangler, ZX6
Tampa
Any amp that does a TRUE 6-900w rms. Mono class D.
TBSpyder is offline
Old 05-06-2008, 07:32 AM   #8 (permalink)
Car: Chevy Cavalier
Seminole
My amp's model is XM-ZR1582. It doesn't say its RMS rating on the amp and I don't have the box anymore. I even googled the model and nothing turns up.
Sponsored Links
