#1 (permalink) |
^ likes 2.4l's
Car: has 2.4L
New Port Richey
: 367643412 |
amp cuts in and out.
I have an older 1kwatt amp, it cuts in and out during play. But it doesnt lose power. It just pulses, and seems to not want to produce bass. I broke it open, and looked but nothing seemed wrong with the board. What could be the issue?
And yes it has brand new wiring/fuses so thats not the issue. Thanks in advance, -Mike |
#3 (permalink) |
^ likes 2.4l's
Car: has 2.4L
New Port Richey
: 367643412 |
I have bro, It only does it with this amp. My other amp works fine. Im thinking that something may be wrong with the amp itself, but as I said. The board looks fine. I didnt see any damaged resistors or cracks in the board.
#4 (permalink) |
hell yeah son
Car: Wrangler, ZX6
Tampa
: 28649711 |
Well if it only does it with that amp, it's the amp. Problem solved. And you usually can't "see" anything wrong with an amp unless you caught the thing on fire. Sounds like you're just going to be stuck buying a new amp.
#9 (permalink) | |
is a street vacuum
Car: 2007 MazdaSpeed6
South Tampa, Northdale.
: 487285551 |
Quote:
Though, I fear it still may be with the wiring. Take all the other amps out of the picture. Only put in that amp. Fixed? Try putting in another amp, if it still works, recheck wiring while putting in third (assuming you have that many). Still have the issue? Might just be the amp itself. Get a new amp! new technology rocks, the market doesn't. |
#11 (permalink) |
Hates Cars
Car: 1989 Mustang LX Coupe 5.? & 2007 Grand Cherokee
Clearwater,FL
: 283215035 |
dude what it sounds like u dont have the amp wired right you said it was a older amp what ohm rating are ur subs and and what can the amp do alot of older amps cant run in 2 ohms and can check how many ohms your subs and putting out with a volt meter and it can also be a bad ground or the power wire is too small and cant get the wattage needed to run the amp.Just trying to help look in to these things.
#15 (permalink) |
Car: Exploderer!
carollwood
: 62705444 |
+1 Ohm rate WILL effect the amp. I had the same problem with one of my older amps, turns out that the amp wasn't able to run at 1ohm, try switching it to 4ohms at the least. If the problem still occurs then its time for a new amp.
| Sponsored Links |
