#1 (permalink) |
FAF is teh gh37!!11
Car: custom 3 wheel bike
Lakeland
: 317976830 |
wiring
cleaned up my wireing a while back and wired 2 door poppers in awhile back... tonight i redid the wireing for the cd plyer eq and ampkill switch pics..
![]() ![]() wireing for center consol.. ![]() starter switch and ampkill switch.. ![]() ![]() ![]() ![]() door popper wireing.. ![]() under the hood |
#4 (permalink) |
King of Ricers
Car: =
Tampa
: 195694775 |
Kauluz dont repost pics it clutters the thread.
1stgen, thats clean wiring minus the lack of a grommet or some type of insulating material (fill the hole with silicone its $2 from walmart) Even if you dont do that, I would run a single 12ga wire from the batters and put a fuse on the end of it - you can get a blade type inline fuse holder from walmart or autozone for a dollar or two. then bind all the wires with heat shrink to the end of the fuse lead. Also shouldnt that starter switch be a momentary button? I can only imagine you cruising down the road and bumping that switch and having it grind your starter to hell. |
#5 (permalink) | |
FAF is teh gh37!!11
Lakeland
: 317976830 |
Quote:
| Sponsored Links |
