Forums Register TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Audio HQ
Old 03-04-2008, 04:59 PM   #1 (permalink)
Big Nate
Car: 1992 Cadillac Deville
Clewiston, FL
brownguy06 is a jewel in the rough: 251210
Question A dual 1.5 ohm subwoofer makes what?
Does anyone know what ohm a dual 1.5 sub wire's down to when wired (+,+, and -,-) is it a (0.5) load or a (1.0) load even..I was checking out the (JL Audio W7's) and they are dual 1.5 ohm. and i would like to get 2 of the (JL Audio 1000/1) amp or 2 of the (Orion HCCA D2400) but dont know if an orion amp can handle a (0.5) load. I honestly dont think that you will get the full effect from a JL if you dont have all the power running to them that they need. so how about if i ran a (Orion HCCA D5000) to both its a little more power then is recomended for the W7's but i would need to know what the W7's wire down to so that i dont run ohm loads to the amp if the amp itself cant handle it..
brownguy06 is offline
Old 03-04-2008, 07:02 PM   #2 (permalink)
Car:
the727kid has a reputation beyond repute: 39382284
Why you wanna go with W7s? There are many subs out there better and cheaper. Secondly.. 1.5 is either .725 or 3 ohm load.
the727kid is offline
Old 03-04-2008, 07:04 PM   #3 (permalink)
Big Nate
Clewiston, FL
i dont know i thought that w7's were a really good brand.. so they wont run at a 1 ohm load then.
Old 03-04-2008, 07:06 PM   #4 (permalink)
Car:
No they won't, JL does that so basically your confused into buying a JL1000/1 becuase it produces the same wattage from 1.5 to 4 ohms. Just a slick marketing move.
Old 03-04-2008, 07:13 PM   #5 (permalink)
Big Nate
Clewiston, FL
ah indeed...so what do you think would be the best route to go..im into BIG BASS but im going to only have enough room to run a pair of 12's so what do you think i should pick up..or check out for myself.
Old 03-04-2008, 07:17 PM   #6 (permalink)
Car:
Well if your into serious bass, check out some Fi BTLs.
Old 03-04-2008, 07:24 PM   #7 (permalink)
Big Nate
Clewiston, FL
Are they really that good..and what kind of amp should i put to them?
Old 03-04-2008, 07:31 PM   #8 (permalink)
Car:
At minimum 2kw per sub... ideal is more like 3kw per sub.
Old 03-04-2008, 07:52 PM   #9 (permalink)
Big Nate
Clewiston, FL
so 3k would push the hell out of the subs...got it. I checked out the site and there are different set ups for the subs. what would be the best? there are cooling and adding other magnets..i just want whats going to hit the hardest.
Old 03-04-2008, 07:56 PM   #10 (permalink)
Car:
Fully-Loaded would perform the best.
Old 03-04-2008, 08:01 PM   #11 (permalink)
Big Nate
Clewiston, FL
what kind of amp would you preffer i was thinking of running 2 seperate amps to each sub but dont know what amp to go with...what is the peak on the subs and the rms? that would help my search a little bit better.
Old 03-04-2008, 08:06 PM   #12 (permalink)
Car:
RMS is 2000 for the base sub no options. Peak umm well, that's not really a number anyone cares about. Steve Meade sends his 4kw daily, they have been burped with 20kw... not too many subs that have more output. DC LV5, RE MT, IA DP, DD9500(or 9900), are all subs that are in some catagory.
Old 03-04-2008, 08:08 PM   #13 (permalink)
Big Nate
Clewiston, FL
ok then no proble so what do you think if i run 2 Orion D5000 amps. one for each sub?
Old 03-04-2008, 08:12 PM   #14 (permalink)
Car:
Does 2500@1ohm? Would be pretty good. Your looking at some money for all that run properly though.
Old 03-04-2008, 08:16 PM   #15 (permalink)
Big Nate
Clewiston, FL
yeah i know im building a show car with a great system in it..but i cant settle onto one sub.. thats why i come to here for some info..so that way i kind of have an idea of what would be good. so fully loaded 12 fi btl's with 2 orion hcca d5000 sounds like a good set up?
Sponsored Links
