Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Audio HQ
Old 12-16-2007, 06:00 PM   #1 (permalink)
Don't Drink And Drift
Car: 93 s13
Tampa
kober has a reputation beyond repute: 12377735
quick headunit installation question
ok i took out my old stock headunit on my 95 240sx.. and i did everything right so far but now i dont know what to do.. the power wire is different from the car.. it wont connect.. on my previous 92 240 the power wire match perfectly.. heres a pic if u dont understand what i am talking about
this is from the car... (2 things)
and this is from my alpine headunit (1 hole)
any ideas what to do? i am sorta a newb.. so i duno
thanks. and rep will be giving..
kober is offline
Old 12-16-2007, 06:51 PM   #2 (permalink)
Car: 2000 Dakota R/T
Hudson
irupp33 is on a distinguished road: 1803
That looks more like an antenna wire...
irupp33 is offline
Old 12-16-2007, 07:03 PM   #3 (permalink)
Go scoop shit.
Car: 99 Yukon,92 KX 125,96' Banshee,240sx/ls1(one day it will be done)..
Tampa
Skittle has a reputation beyond repute: 2147483647
Yea looks like your missing the wiring harness for the Alpine cd player,The hole thing your holding is for the antenna.
Skittle is offline
Old 12-16-2007, 07:13 PM   #4 (permalink)
Yeah, it's a HEMI..
Car: 2004 Dodge Ram 1500 5.7L
Clearwater, Fl
aleister2k is an unknown quantity at this point: 10
looks like your antenna has a dual wire post instead of a wire surround wire normal setup. Your local bb/ cc should be able to sell you an adapter for it. They may not have it in stock, but hey are generally under $10
aleister2k is offline
Old 12-16-2007, 11:01 PM   #5 (permalink)
Car: 93 s13
Tampa
oh ok thanks.. ill pick one up tom..
ok well it still wont power up for some reason.. im not sure why.. i just got the 240 and the stock radio never powered on.. so i check the fuses which i replaced the radio fuse.. still no go. the alpine headunit still doesnt power on.. idk what to do now.. argg
kober is offline
Old 12-16-2007, 11:41 PM   #6 (permalink)
King of Ricers
Car: =
Tampa
Notladstyle has a reputation beyond repute: 199523425
Just run new power wire and accessory wire from the ignition column and run a ground wire to a sanded point against the chassis.
Dealing with old stock harnesses is a hassle that is better skipped.
Notladstyle is offline
Old 12-17-2007, 06:00 PM   #7 (permalink)
Car:
TJElite has a reputation beyond repute: 85858618
Also, if I remeber right, 240's used a seperate ground on the chassis of the radio...its not in the harness. Most of the aftermarket harnesses have a black wire for you to hook your headunit to, but if you look, it doesn't connect to anything in the factory harness. You'll need to run a new ground, which like dalton said, isn't a bad idea anyway.
Toby
TJElite is offline
Old 12-17-2007, 09:56 PM   #8 (permalink)
Project.S
Car: S13 Coupe, 2004 zx-10r (Green)
The Place Where The Black People Are Lazy And The White People Are Just As Lazy, But They're Mad At The Black People For Being So Lazy
Hotcakes0007 has a reputation beyond repute: 138240928
umm the ground on a 240 s13-14 the ant is the ground....just in case no one new also yes its a ant adapter which plugs the stock one in and comes with another for the headunit...
Hotcakes0007 is offline
Sponsored Links
