#1 (permalink) |
is a street vacuum
Car: 2007 MazdaSpeed6
South Tampa, Northdale.
: 581959160 |
Wiring DVC to two amps?
Someone asked me this the other day, is it possible to wire up a DVC subwoofer to either two amps or 1 4 channel amp (bridged on each VC?)
I told him that I think its technically feasable, but that all settings have to be exactly the same so the VC's move as close to the same time as possible? Am i wrong though? Would this just end up ruining the subwoofer? |
#3 (permalink) | |
is a street vacuum
: 581959160 |
Quote:
oh well i'll just recommend he not do it, i was leaning towards that anyways. |
#5 (permalink) |
King of Ricers
Car: =
Tampa
: 199523425 |
If the amps do not have strapping (theres a plug and a master/slave switch) you will not be putting out identical signals.
This might cause probs at high wattage as even a slight misalignment will lead to extreme drop in resistance between the coils - like a sudden drop to zero ohms. which could damage the amps and overheat the sub. |
#6 (permalink) |
Car:
: 45038733 |
Only possible with strappable amps.
| Sponsored Links |
