Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Audio HQ
Old 03-07-2007, 02:54 PM   #1 (permalink)
Sound Engineer for Hire
Car: Honda Civic
New Port Nowhere
djgizmo will become famous soon enough: 70013
lol, now I have a problem
Summary: Alpine-MRV 545 - 4x20amp fuses pop each time power & ground is connected to amp.
ok, a few weeks ago my amp stopped turning on. I didn't think anything of it since I was so busy, figure the ground just slipped.
I tried working on it today and everytime i attempt to connect power to the amp, the 20am fuses pop. So I figure, its probably a speaker grounded. So I disconnect all the rca's and all the speakers from the amp. Try again, POP, another fuse pops (right now I'm trying them 1 at a time since I popped 4 already) The instant I connect power, the fuse pops.
I figure its might be the remote wire. Pull that, try another fuse, POP. Ok, so then I pull the ground out of the amp, connect up the wire. No pop. (of course)
I'm not sure whats causing this. Any ideas?
djgizmo is offline
Old 03-07-2007, 03:30 PM   #2 (permalink)
is a street vacuum
Car: 2007 MazdaSpeed6
South Tampa, Northdale.
P057 has disabled reputation: 581959160
that shit is getting expensive.
P057 is offline
Old 03-07-2007, 04:13 PM   #3 (permalink)
Car: Honda Civic
New Port Nowhere
lol, no shit. spent about $4 in fuses already. Any ideas?
djgizmo is offline
Old 03-07-2007, 04:42 PM   #4 (permalink)
is a street vacuum
Quote:
if i did i would have posted something other than that obvious statement. Sorry dude.
P057 is offline
Old 03-07-2007, 11:18 PM   #5 (permalink)
Car:
the727kid has a reputation beyond repute: 45038733
Your amps gone.
the727kid is offline
Old 03-08-2007, 12:03 AM   #6 (permalink)
King of Ricers
Car: =
Tampa
Notladstyle has a reputation beyond repute: 199523425
I was reading around after you called, the amps powersupply caps will pull a massive amount of current when it is first plugged in, make sure you have all four? fuses in before you connect the power line - GROUND FIRST.
also disconnect the RCA lines, and check for 4ohms at the subwoofer - bridged isnt 2ohm stable and I cannot remember if you purchased the 4ohm or 2ohm when we installed it!!!!
Notladstyle is offline
Old 03-08-2007, 01:17 AM   #7 (permalink)
All American, rice eater!
Car: 70 chevelle, 03 f150,
GradeA_TireFryer has a reputation beyond repute: 78159956
amp is toasty
GradeA_TireFryer is offline
Old 03-09-2007, 05:28 PM   #8 (permalink)
Car: Honda Civic
New Port Nowhere
Ok, I'll try hooking up all 4 fuses. (hopes it doesn't blow all 4 at the same time)
I can't find the manual off the net for the MRV 545 (at work right now). I THINK i still have the manual in my filing cabinet. Since the caps will pull a massive amount of current when its first connected, do you recommend upping the fuses to 25amps? (vs 20) Granted the second the 20amp fuses pop currently, its not a lil pop, you can see where the metal melted inside the fuse (at the popping bridge)
I'll leave everything else unplugged and try your suggestion. all 4 fuses, then ground, then power. I bought it from a reputable online store (local places wanted to charge double to 2.5x as much), so hopefully they'll be able to do a warranty exchange. (surprisingly they still have this amp in stock)
djgizmo is offline
Old 03-11-2007, 01:50 PM   #9 (permalink)
Car: Honda Civic
New Port Nowhere
Well I looked at the amp, didn't see any 'sticker' that showed void if removed. So I cracked her open. 38 screws later I find this. Seems that water got in the amp (think it happened during a car wash and my trunk of course leaks... DAMIT!) and looks like it blew a mosfet, but since I'm no electronics expert wanted to ask you guys.
Also, I heard that ESS in NPR does amp repair, anyone have their number? If anyone else is willing to repair that chip, I'm also willing to bring it to them if the price is fair.
djgizmo is offline
Old 03-11-2007, 02:58 PM   #10 (permalink)
King of Ricers
Car: =
Tampa
wheres the heatsink?
Old 03-11-2007, 09:53 PM   #11 (permalink)
looks lie he unscrewed it from the heat sink - told ya - toasty
Old 03-11-2007, 11:49 PM   #12 (permalink)
King of Ricers
Car: =
Tampa
I see heat stress on the board - cut your losses and replace the amp.
Old 03-12-2007, 12:09 AM   #13 (permalink)
Car: Honda Civic
New Port Nowhere
read ABOVE! I unscrewed everything and pulled it out. AKA HEAT SINK NOT GOING TO BE ATTACHED while its out.
Quote:
djgizmo is offline
Old 03-12-2007, 12:11 AM   #14 (permalink)
Car: Honda Civic
New Port Nowhere
Dalt, its a $15 mosfet chip thats blow, thats all, why throw a $350 amp away because of a $15 repair. I'm willing to pay $60 if someone is willing to do it, but theres no way I'm going to trash it. Dalt, for a person who's going for their electrical engineering degree, its not a really a 'can do' attitude. Shit, if I had the needed soldering skills (still don't, probably won't till after this is fixed of course) I'd fix it myself.
Its not heat stress on the board, its stupid corrosion from the dam water that got in the amp and dried.
djgizmo is offline
Old 03-12-2007, 02:30 AM   #15 (permalink)
King of Ricers
Car: =
Tampa
Whether it be heat stress or corrosion, every other component on that board, the solder joints, and the board itself have all been stressed and probably damaged
You might get it working with a quick FET swap, but it will be not the last of your problems...
Tis the way with technology.
Sponsored Links
