help on Porting cab to bed of the truck
Old 01-07-2007, 07:26 PM
weekendsliderz's Avatar
Default help on Porting cab to bed of the truck
I want to port the bed to my 95 standard cab ranger and I'm looking for tips on the best way to do it. If anybody has pics from the buildup or completion of this project post them up.I am gonna seal up the bed and put a hard tonneau on it(If you have one that will fit let me know), But what is the best way to form a port between the cab and bed? Any tips will help.Thanks.
Join the anti-rice movement at anti-rice.com
If you fail with 4
You might have better luck with 8
If you fail with 8 then you suck at life buy a bike
If you still lose to an import on your bike, buy a family car and settle down
Old 01-07-2007, 08:16 PM
TBSpyder's Avatar
I've done a couple. Cut a big hole through the cab and bed...then there is this boot material (like a large rubber gasket) that a couple car audio install material suppliers sell, which is the best way to seal it all up. Then just basically build a sub enclsoure and run the ports through the hole.
Old 01-08-2007, 05:14 AM
All American, rice eater!
GradeA_TireFryer's Avatar
+1 thats the only way to do it - i have done dozens of them that way - protect the boot - they tear easy
Pirate Customs
Sound, Security & Style..... anything for your ride
Old 01-08-2007, 10:28 AM
should the ports of the box go directly into the hole or can it sit anywhere in the bed? Protect it how?
If you fail with 4
Old 01-08-2007, 11:16 AM
King of Ricers
Notladstyle's Avatar
Build a sealed box in the bed, cut holes to let the bass in. really simple. sealing it is the hard part.
Integralsgreen was talking about welding a box into place and skipping the gasket alltogether a while ago. He disappeared before he put it into action.
notladstyle.blogspot.com
Old 01-08-2007, 12:36 PM
Depends - I Have Done Both - If You Just Want To Port The Box Into The Cab I Have Dont That With Pvc And Silicone, But What I Have Done Mostly Is Cutout The Back Of The Cab And Front Of The Bed (becarefull To Leave A Lip For The Boot Material To Slip Over) That They Use For Topper Installs (you Can Buy It By The Foot) I Use Silicone In The Groove Of The Boot To Keep It From Pulling Out, Then I Build A Floor Over The Bottom Of The Boot - If You Dont You Will Rip It And Then Water Will Get It.
If You Buy A Snug Topper I Have Cut The Hole Back Of The Bed/cab Out To Make A Walk Thru, Then 12 - 15's Are Easy To Put Back There Or I Have Done BED Caps, And Cut Out A Port To Let A BanDpass Box With 8 15's Breather - Good Luck -
Pirate Customs
Old 01-08-2007, 06:32 PM
TJElite's Avatar
I'll be doing one on our new shop truck in the next week or so. We're doing a topper, so I'm going to basically cut everything out, making it suv-like, as Grade A mentions. I've found a couple of different gasket ideas. One is the standard accordian boot, that lots of people use, and can be bought at many truck stores, and online. It 'clamps' to both sides, and flexes in the middle. The other material is more like a big noodle...sticks to one side, and then smashes up against the other. I think this will work better in a moving vehicle, and be less prone to tearing.
I'm out in Vegas at the CES show, but I'll post some links to the gaskets when I get back.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old 01-08-2007, 07:23 PM
both of those sound like something that I could work with so if you have a link to that or pictures of work you've done it would be greatly apreciated.Also with the pvc pipe into the cab would you still get the same amount of bass inside the cab? And what size should I use for two 12in in one box?
If you fail with 4
Old 01-08-2007, 08:23 PM
This is basically what I want to do but what should I use to fill in that gap?In-Bed Woofer Install - Tech - Truckin Magazine
And a box like this would be perfect but should I leave the back of the box completely open and just snug it up against the hole in the wall and seal up the cracks or specifically cut to fit the opening?In-Bed Woofer Install - Tech - Truckin Magazine
If you fail with 4
Old 01-09-2007, 04:29 AM
Mount The Box Tight Against The Rear Wall Of The Bed - I Would Coat The Out Side Of The Box With Resign To Prevent Any Water Damage, Then You Could Use 2 - 4" Pvc To Port Into The Cab - Size And Length Of Port Depends On Box Design , Just Design It So The Ports Extend Out Of The Box Instead Of Into The Box, - If You Were Going Thru All The Trouble To Do This I Would Do More Than 2 12's - Maybe 4 Or A Couple Of 15's
Pirate Customs
