#5 (permalink) |
Car: 03 bmw 330i zhp
lakeland
: 65 |
ok bridged makes my amp go into protection at higher volume....so I have it wired up like this
![]() and it doesn't cut out and sounds fine....is that safe or will I cause damage to the subs? 2 12' infinity perfect 12.1's |
#7 (permalink) |
Your Moms New Boyfriend
Car: '05 Blazer, '72 Caprice "In Progress"
Sticks of Tennessee
: 3436913 |
That Kicker amp should be good for 4ohms bridged with no problems.......
Its fine to run it the way you have it now, it wouldnt hurt anything, but you have a 4ohm load to each channel and the jumper wire isnt necesary (you are only using 1 voice coil in your diagram). If you are going to run 2 channel, try this... Wire each sub like this on seperate channels and let us know, may be a problem with your amp. Last edited by joebobclark : 05-15-2006 at 01:34 AM. |
#8 (permalink) | |
Leaving March 6th
Car: 2005 VW GTI 1.8T
Charleston AFB, SC
: 358 |
Quote:
#9 (permalink) | |
Sticks of Tennessee
: 3436913 |
Quote:
#11 (permalink) | |
Sticks of Tennessee
: 3436913 |
Quote:
You are running 4ohms now, but only using 1 voice coil (if its wired like your diagram). If you are going use 2 channels, you should wire for 2ohms. If the amp goes into protection with 2ohm stereo, it may be messed up. |
#13 (permalink) |
Sticks of Tennessee
: 3436913 |
It should be good for 4ohm mono (bridged) and 2ohm stereo (not bridged) with no problems, most any amp on the market will hold that.
But you said that at high levels, it was going into protection mode with a 4ohm mono load, when it should be good for a 2ohm mono load. If it goes into protection with a 2ohm stereo load, it may be the amp has a problem. |
#14 (permalink) | |
Leaving March 6th
Charleston AFB, SC
: 358 |
Quote:
#15 (permalink) | |
King of Ricers
Car: =
Tampa
: 229487081 |
Quote:
ive been running my d312d2 on one coil since I got it. |
| Sponsored Links |
