Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Audio HQ
Old 05-04-2006, 08:01 AM   #1 (permalink)
Bewbie Ricer Type-R
Car: 1988 300ZX Turbo
Tampa
Largo has a reputation beyond repute: 97512305
Amplifier questions
So, doing some research, i've decided I want to get 2 ascendant audio assasin 10's. But now I need an amp, and I have no clue about amps, I just know I want to be able to push these amps well, at 4 ohms. Manufacturer says recommended power is 200watts, so I would want a 400/2 amp that runs at 4 ohms... anyone have any advice on amps?
Largo is online now
Old 05-04-2006, 09:06 AM   #2 (permalink)
Car:
TJElite has a reputation beyond repute: 85858618
Quote:
I'm not sure what you mean by 400/2...I'm assuming you mean an amp that has can deliver 400 watts into two channels. Also called 200x2. That would work, but is not ideal, imo.
I'd go for a mono Class D subwoofer amp that is stable to 2 ohms (two 4 ohm subs in parallel). Amongst other benefits, Class D will be lots more efficient. I'd also probably look for something that is more like 500+ watts at that level, since I prefer to provide more than the RMS power to the subs. You're actually less likely to blow them this way. Ideally, you'd pick up a 1 ohm stable, 1000 watt amp...that would give you the 500 watts at 2 ohms you need now, and give you room to add two more subs down the road. The Crossfire VR1000D meets these requirements, as do many other amps, I'm sure. This month's Car Audio and Electronics is the annual directory issue, and lists specs for most of the major brand amps. You might want to pick one up somewhere.
Toby
TJElite is offline
Old 05-04-2006, 10:23 AM   #3 (permalink)
Bewbie Ricer Type-R
Tampa
I'm looking more for a 2 channel stereo amp. so I would prefer not to get a mono block
Largo is online now
Old 05-04-2006, 01:23 PM   #4 (permalink)
Car:
Why do you want a stereo amp for subs? There is no benefit that I can think of, and you'll spend more, for less power, and lower efficiency.
Toby
TJElite is offline
Old 05-04-2006, 01:26 PM   #5 (permalink)
Ru Noises...
Car: 2008 LGT
Clearwater, and Ft. Myers
VolvoBoiClw has a reputation beyond repute: 5869636
agreed, go mono, bridge it, better sound..
VolvoBoiClw is offline
Old 05-04-2006, 01:49 PM   #6 (permalink)
Just Ledoux it!
Car: 2000 Ford Ranger
Fort Myers
93ex has a reputation beyond repute: 64697689
For subs, monoblock. Save the hassle.
93ex is offline
Old 05-04-2006, 03:36 PM   #7 (permalink)
Car:
mbanks21 is an unknown quantity at this point: 690
Quote:
Ill give you a second to edit that....
Okay, did you suggest to bridge a mono amp?
mbanks21 is offline
Old 05-04-2006, 03:37 PM   #8 (permalink)
Car:
Oh, and I suggest a JL 500/1
mbanks21 is offline
Old 05-04-2006, 04:55 PM   #9 (permalink)
King of Ricers
Car: =
Tampa
Notladstyle has a reputation beyond repute: 229487081
I so didnt catch that
maybe you meant bridge the subs together
Notladstyle is offline
Old 05-04-2006, 05:48 PM   #10 (permalink)
is a street vacuum
Car: 2007 MazdaSpeed6; 95 Accord
South Tampa, Northdale.
P057 has disabled reputation: 581966026
Maybe he thinks with a 2 channel he can power a sub on each channel and avoid having to use two amps for each sub? i dunno thats the only kind of (il)logical reasoning i can think of for why he'd want to do that..
P057 is offline
Old 05-04-2006, 06:14 PM   #11 (permalink)
Car:
One mono amp can run multiple subs. Mono D amps are more efficient and are designed to run subwoofers. Are the subs dual 4 ohm?
mbanks21 is offline
Old 05-04-2006, 06:51 PM   #12 (permalink)
It's a wooden pickle.
Car: SRT-4
orlando
Miles has  hit bottom,  and can only go up!: 10434124
get a mono amp. stop being gay.
Miles is offline
Old 05-04-2006, 07:40 PM   #13 (permalink)
hell yeah son
Car: Wrangler, ZX6
Tampa
TBSpyder has a reputation beyond repute: 28649711
Quote:
TBSpyder is offline
Old 05-04-2006, 09:26 PM   #14 (permalink)
Bewbie Ricer Type-R
Tampa
haha, yeah, and that would be the reason to get a dual channel. I don't listen to pop music, more rock, so the bass can hit on either channel depending on the recording company basically. I would prefer to use a stereo sub vs 2 mono blocks. But again, I don't know much about amps so maybe this is the wrong way of thinking
Largo is online now
Old 05-04-2006, 09:30 PM   #15 (permalink)
Just Ledoux it!
Fort Myers
Quote:
or he wants to someday power other speakers with them.. he could power some real good components. Just sayin.
93ex is offline
Sponsored Links
