#1 (permalink) |
Car:
: 10 |
Power wire and ground touched..wont work..plz help!
while pulling out my system...my power wire touched my ground wire..now the amp wont work..i changed all fuses throughout the whole car..still nothing works...is it possible it is something small..and if so how much do u think it would cost..the local place called AVS wants 40 just to look at it...could u guys maybe help me out on this...im kinda new to all of this! Thanx alot!
#3 (permalink) |
Maximaniac
Car: 2k maxima
Lutz
: 118 |
back when i was an audio newb i accidentally hooked up the +12V to GND and GND to +12V. It was a Jensen 4 channel amp, and from then on, 2 of the outputs crapped out. It was only powering 2 10" punch z rockfords, so i just bridged the 2 other channels and it works ok. If youre sure all the fuses are fine, especially including the in-line fuse on the power wire coming from the battery, and the fuses on the amp itself...then the only option is an audio shop.
#7 (permalink) |
Car:
: 10 |
regular comps...c12
they hit nie as hell in my car...rattled everything..they were nice till the amp blew..pissed me off cus i went to mount the bitch..and the dick who set it up didn;t crimp the power wire enoguh and it hit the ground sparked all over and wouldn't work |
#14 (permalink) |
F*ck Tom Brady
Car: 2004 GMC Sierra
Palm harbor
: 5486356 |
depending on the amp A&B audio will usually charge $45 to fix it. A friend of mine just did the same thing $45 to fix it. The guy said thats the norm..
| Sponsored Links |
