walbro fuel pump question
Old Jun 5, 2003 | 12:43 AM
JTP's Avatar
JTP
Been here a while.
I dunno, but ever since I installed my fuel pump.. It's like I am hitting fuel cut on the LAUNCHES.. not sure WTF is going on but it is ANNOYING.. also when I power shift.. the car will start to studder :-\?
Old Jun 5, 2003 | 07:28 AM
PoppaSmurf's Avatar
Chowdah-head
hack the mass air, or put the 2g mas on
Poppa J. Smurf
Old Jun 5, 2003 | 07:50 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
not sure if they are interchangable, but if your doing a fuel pump make sure you wire the pump directly to the battery, DSM's have a problem with getting voltage to the pump at high RPM's
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Jun 6, 2003 | 06:15 PM
psifactor's Avatar
Hello
they are all the same. Supra MK3, Supra MKIV, Mustang, Trans Am, Camaro, DSM, Stealth /3SI will all use the same pump. its basically universal.
only a few are Drop-in like the Denso 190 lph, but thats too small to bother with. if yoru gona go thru the trouble, get the 255HP or Supra TT pump.. i know Supra pumps have to be zip-tied to the pump assembly before dropping into the tank. so, it could be the same for the Walbro... im not sure since our car CAME w/ the 255 already installed.
the DSM's have problems getting full voltage at ANY RPM... we are about to turn the 4GA speaker amp cable into the power cable for the fuel pump... no voltage drop here
Heavy car with a 2.5L
