Levi
05-24-2003, 02:42 PM
Check the injector signals coming from the power module (or SMEC). They should rise to about 12V when the injector is off and drop close to 0V when the injector is on. If they are out of spec, you may need to replace the power module.
Now reading that above statement, Are they saying Testing with the key on or off?
I pulled #2 injector wire, tested it No voltage with key on or off.
Does the engine need to be running to have voltage @ the harness?
