View Full Version : RWD launching?
Cronic
02-14-2003, 09:54 AM
I might be going to 1320 tonight, want to see what the 280 turbo runs mostly stock (9psi+3" exhaust).
Ive only "raced", I use that term losely... FWD cars. I would like to know what to look for and watchout for....
Thanks
i dunno about the 280.. but the mach 1 needed a 2K launch.. when spinning stopped floor it all the way and grab for second real quick.
Cronic
02-14-2003, 10:59 AM
Well the 280 has boost, and much less whp then your car has. I'll try a 3k launch and go from there, I was more worried about the back end sliding around or something crazy. =P
nah.. you should be fine.. launch about 3.. if it bogs too much.. go higher.. you'll find the sweet spot.. launching with boost you can sometimes go a little higher to build a bit of boost for off theline..
Cronic
02-14-2003, 12:05 PM
Yeah, with the Civic I let it rev to 6k, drop it down and then back up, until the last yellow, then I let it die down to 3k for a good off the line boost. Unfortunatly I have POS tires... I spin so much it's horrible.
Not to mention the clutch is shot, so trying to grab second just doesn't happen.
Cronic
Thanks zate. =)
0HP930
02-16-2003, 06:36 PM
Since your car config is close to mine, here is what I do.
I launch at about 4K. Its high enough to allow me to boost quickly and have a decent amount of power at hand, but not too high to where the engine will overpower the clutch and never catch.
Sneakin Deacon
02-16-2003, 10:31 PM
i drove my friends 280zx Turbo at sunshine one night, i had 1.9 launches from 5k and feathering it out.
dsk888
02-18-2003, 09:10 PM
1.79 60' @ Bradenton, dumping the clutch at 3k, and hole shot with nitrous fully engaged, planting over 500 ftlbs of torque to the pavement. ---> Nitto 555Rs
Good luck to ya! :D
Strokd85
02-18-2003, 09:17 PM
coming out of the hole @ 5800, getting 1.3x 60' times with the rear wheels... :D
98MODMTR
02-18-2003, 09:21 PM
Good luck to ya! :D
hmm, i come out of the hole at 4k with a solid 250 ft/lb of tq hitting the pavement and cutting 1.79 60s on 17in 555r's.
weird....
dsk888
02-18-2003, 09:38 PM
weird....
...guess you're not spinnin... :D
Sneakin Deacon
02-18-2003, 09:56 PM
thats cool, im still cuttin 1.8 on shitty street tires, go me :D if i start making more power i can probably pull a low 1.7 on them. if i actually launch at 5500 like i should i think i can pull a high 1.7, but im afraid of being at the track and breaking an axle or my driveshaft.
98MODMTR
02-18-2003, 10:02 PM
how the hek did I get to the other end of the track?:D
Content Relevant URLs by
vBSEO 3.2.0 RC5
