View Full Version : Turbo Drain Problem Need Suggestions!!
~Boost Freak~
02-05-2003, 04:20 PM
a have a garrett to4e turbo and the moroso pan the problem is, that the drian bung off the oil pan and the turbo drain line are so close to gether that i can get one to the other without kinking or routing around like the grand canyon... any one have this prob?? or any suggestion on how to fix?? :?:
Cronic
02-05-2003, 05:49 PM
copper 90degree bend?
99B16Si
02-05-2003, 06:27 PM
i had the same problem so i went to amazon hose and bought some high temp line that actually has strips of metal through it that doesnt allow it to kink. its a little hard to bend but it worked perfect for me. just go there and ask for just that. theyll hook you up and its only like 5-10bucks a foot
Cronic
02-05-2003, 08:20 PM
steel braided?
~Boost Freak~
02-06-2003, 09:20 AM
i have steel braided #10 (5/8) and the angle its on its insanely tight i think i might have got it but won't know till tommorrow (friend punctured radiator on accident :x ) anyway i use barb fittings insted of the screw on type and it seems to have work will update when finished... :)
99B16Si
02-06-2003, 06:34 PM
Originally posted by "CronicBurn"
steel braided?
no damnit. not steel braided, if it meant steel braided i would have said it... steel braided will still kink. it looks like a normal high temp black silicone line but its got strips of metal through it. just do what i said and be done with it
highoctane
02-06-2003, 07:06 PM
Sounds similar to hyraulic hose, rubber hose reinforced with steel wire
Content Relevant URLs by
vBSEO 3.2.0 RC5
