87-93 Mustang Gt on welds, wing, cowl hood
Going down 60 heading to the valrico area where 60 becomes pretty dark and no cars are newhere to be found i came up on a black mustang with welds etc..... I get up next to him and down shifted to 3rd he did as well we both hit it and i began to pull him little by little went into 4th and i had about a car to a car and a half on him . we let off and did it again from a 2nd gear roll (BAD IDEA) hit it and spun and he began pulling me through what left of 2nd i had and through 3rd. After we ran we stopped at a gas station and talked. Kool guy and a strong running car. Thumbs up bro awesome race. Gotta go from a 2nd gear roll again
Jason
Jason
Scott, Def not the old carb
Got all of the crap outta the way that night. I pulled the intake gasket off that night after the 2nd pass on the dyno . went through and re timed it and the distributor was WAY out .... :o We timed it again and came out right . Still need to tune the carb alot. How did you make out with the new carb . I saw you lost alot of Hp due to it , but left after the last pass on the dyno .
Jason
Got all of the crap outta the way that night. I pulled the intake gasket off that night after the 2nd pass on the dyno . went through and re timed it and the distributor was WAY out .... :o We timed it again and came out right . Still need to tune the carb alot. How did you make out with the new carb . I saw you lost alot of Hp due to it , but left after the last pass on the dyno . Jason
Guest
Posts: n/a
Jason
We got back to a 2 h.p. loss and 6 ft. lbs. of torque loss. It is still running to fat so the h.p. will go up when that gets fixed. We thrashed on it until almost 8:00. Putting it back on the dyno Saturday to work out the rest. Make sure to get John to finish yours up, he says he knows what will do it.
Save yourself the hassle of tuning a carburator, and get a mod motor
Marisela
Marisela
“Meditation brings wisdom; lack of mediation leaves ignorance.
Know well what leads you forward and what holds you back, and choose the path that leads to wisdom.”
~ Buddha ~
~ Buddha ~
Originally posted by "FordMan"
Why ?
Once you get the carb right it is done, now the mod motor ?
Show me a good running carb'd daily driver around here then??
Marisela
Marisela
~ Buddha ~
~ Buddha ~
