PDA
View Full Version : need some help with nitrous
integra
12-23-2002, 05:08 PM
Ok im having a lil bit of trouble with my nitrous kit. First i baught it off tuffy. He had everything taped up so it was an easy install. Ok the problem i turn the bottle on and flip the activation switch and floor it nothing happens. i moved some wires and made sure everything was nice,unhooked the fogger thing from the intake and turned the car,the bottle,and the activation switch, hit the throttle switch and nothing sprayed. what could be the problem?
98MODMTR
12-23-2002, 07:02 PM
[quote="integra"] He had everything taped up so it was an easy install. quote]
There is ur problem
Cronic
12-23-2002, 07:12 PM
I don't know anything bout n2o installs... Perhaps it's not getting power somewhere, or a bad ground? Start with the switch. Then check the lines and see if they're properly working... Just a thought.
VVTL-i
12-23-2002, 07:16 PM
What kit you have?
if you have everything wired correctly and still not working, it might be your nitrous solenoid...
integra
12-23-2002, 07:33 PM
thanks guys for the help but it was working the whole time he said its just ganna pull harder but feel the same
Strongest Man In The World
12-23-2002, 09:19 PM
is the fuel line not spraying either
take both lines out of the intake tube, have some one turn on your car to the acces. position flip the switch and push peddle to WOT (assuming u still have his WOt switch on the TB) if one sprays and not the other, than u one of the cylinoids are bad, if both dont spray and u dont hear any clicking from the cylinoids, than it most likely is an electical problem.
check your WOT switch on the TB and make sure both the wiring comming from the arming switch and the one leading to the cylinoids are both conected tightly! make sure the switch is in proper position to be activated by the TB arm
then if that doesnt work, then check your arming switch with a amp tester and see if its reciving power. make sure the wire is still attached at the 'noids.
if all else fails, call jimmy at enhanced concepts, hes the one who originally installed the kit and he can help ya out
i rode in tuffys car when he had the bottle on it, and it deff pulled alot harder than all motor, so (depending on what kinda of motor you have) it should make a night and day difference!
integra
12-24-2002, 11:14 PM
i drive a LS integra
integra
12-24-2002, 11:18 PM
where is this enhanced concpets located? phhone number? if it is the selenoids how much am i looking for to replace them? cause i pulled them out and nothing sprayedd
91MR2Turbo
12-25-2002, 01:44 PM
You did check to make sure your bottle had some n2o in it right?Just stating and easy overlook in your install :D ,good luck later,Ray
12-25-2002, 04:04 PM
hahahahhaah holy crap, that would be hi-frickin-larious
integra
12-25-2002, 06:20 PM
yes the bottle has n20 in it im not that stupid i fixed it today and it pulls really hard
Cronic
12-25-2002, 06:46 PM
congrats what was the problem
Bob22b
12-25-2002, 09:19 PM
Ya ya
12-26-2002, 12:57 AM
integra
12-26-2002, 02:52 PM
there is a new problem. it bogs then takes off. and what can i do if it is detinating?
0HP930
12-26-2002, 03:33 PM
Keep a bag in your car to keep the pieces in after it explodes.
j/k :P
Does your car have a knock sensor and ignition retarding unit? If not you may want to add one.
12-26-2002, 09:43 PM
i dont know what u are doing wrong but it worked perfectly in tuffys car
if u are detonating then u are not getting the proper amount of fuel
check fuel pill
integra
12-28-2002, 04:03 PM
ok now everything is running right and i just need to get the bottle filled and its saturday who fills it the same day and on saturday
CostaSpeed
01-16-2003, 10:45 AM
Are you using a relay? If not get one...a good one. Some times (in most cases) you need to have a true 12V source. Use a relay with proper fuse.
