Shift issue
Old Jan 31, 2012 | 04:58 AM
Big Chris's Avatar
tampa car scene
Default Shift issue
Posting for a friend, he says his altima will not shift unless he revs the car up to 4k rpms. The car is a 95 maual tranny altima all stock, any suggestions what to look at?
Old schooler.
Old Jan 31, 2012 | 06:29 PM
Empire's Avatar
buildin' it
a manual won't shit unless it is at 4k rpms?
strange...
i'd start with the easy stuff,
enough fluid
good fluid
master is working
lines aren't leaking
slave is working
gear lube in the tranny, enough of it, is it good?
pretty much anything beyond that and you'll have to start taking things apart.
It almost sounds like a synchro issue, in which case, it could just need the gear lube changed, or it could be jacked up.
00siboy
Sep 2, 2007 07:43 PM
Rob.M
Jan 14, 2004 04:57 AM
Rob.M
Nissan/Infiniti Tech
9
Jan 13, 2004 03:09 PM
Rob.M
13
Nov 14, 2003 12:05 PM
