DMAX,LS1 Stuff,S13,S14, RB26,TurboXS,N60,FAST,Accusump,ACT.
Old Dec 30, 2011 | 11:22 PM
BFTII40's Avatar
kahtsumoto
Default DMAX,LS1 Stuff,S13,S14, RB26,TurboXS,N60,FAST,Accusump,ACT.
Greetings TR welcome to my for sale thread.
Always willing to negotiate with reasonable people. Prices are OBO if you don't know what OBO means: OR BEST OFFER. It's kind of like bidding on it. You make an offer on the car/part, and if the seller likes your offer best, that's what you buy it for, even if it is less than the original asking price.
I can ship all this stuff at your expense.
Here is what I have for sale: All prices are WITHOUT shipping. Items are in Ocala, that is where you will have to drive to get them if you choose to buy.
Brand New DMAX Silvia S14 ZENKI D1 Spec Wide Fenders [I believe they are +30mm]
395.00 OBO!
Brand New Speedway LS1 99-04 Full Stand Alone Wiring Harness. Mechanical Throttle body.[meaning "cable".]
Take the advantage of GM's electronic engine management system with this Painless Wiring Harness. Complete stand alone harness allows you to install late model GM fuel injected engine and correct computer into almost any chassis.
Besides the obvious economy and driveability benefits, check out these sweet features that make it easy and painless to install:
  • Foolproof factory connections
  • ALDL (diagnostic) plug
  • Computer controlled fuel pump provision
  • GM color code
  • Closed loop design
  • Complete information manual
600 OBO
http://www.speedwaymotors.com/Painless-1999-2002-GM-LS1-Engine-Harness,12339.html
S13 Hatch Kouki tails. I don't remember what brand they are, but they've only been mounted once, never on the car for more than five minutes. Pretty much new. The center piece plate has some peeling where the key hole is, barely noticeable though. 110.00 OBO
S14 ebay tails w/o center piece. These are not in the best condition, but could be cleaned up nicely. They work great just need a little tlc. 30.00 obo just want them gone. *SOLD*
Brand New TOMEI RB26DETT Ornament Plate. This thing is rad, never got to use it though.
65.00 OBO
Turbo XS RFL BOV ONLY no flange. Doesn't look like new its been sitting for a couple of years. Only used it for a couple of months when it was in use. 60.00 obo
N60 MAF Decent condition, not sure what these go for
45.00 OBO
Brand New Fast Fuel Rails for LS V8s. The hardware will not work with a 102mm manifold, its for the older version I believe. If you have a 102mm, Fast has a hardware kit you can buy for cheap off their site. 100.00 SOLD**
Brand New Pro 5.0 Shifter for T56 199.99 OBO
S14 SR Flywheel, Might have to re-tap a few of the holes where the clutch mounts to, but other than that its good, pretty much been beat up on, still works great though. 70.00 OBO
ACT six puck sprung clutch, grabs like king kong, it has been beat up on as well, but not for very long and has quite a bit of life left. 140.00 OBO
Brand New 3qt Accusump! With 20-25 PSI Electric valve.
What is an Accusump?
The Accusump is the original automotive oil accumulator. It is a cylinder shaped aluminum storage container that acts as a reservoir of pressurized oil, to be released when there is a drop in the oil pressure. The Accusump is connected to the pressure side of an engine's oiling system and is charged by the engines own oil pump. Its simple, efficient design revolves around a hydraulic piston separating an air pre-charge side and an oil reservoir side. On the oil side of the Accusump it has an outlet that goes into the engine's oiling system, controlled by a valve. On the air side it's equipped with a pressure gauge(on oil accumulators only) and a schrader air valve, which allows you to add a pre-charge of air pressure to the Accusump.
The basic design of the Accusump Oil Accumulators and Accusump Turbo-Oilers are the same. However, the oil accumulators deliver oil to the engine before starting to eliminate dry start scuffing (pre-oiling) and discharges oil during low oil pressure surges to protect against engine damage during demanding racing conditions. The Turbo-Oilers deliver oil to turbos after shut down to lubricate and cool hot turbo components and prevent coke build up and turbo damage.
ACCUSUMP : 360.00 SOLD** Valued @ 180.00 + the accusump @ 260.00
Parts Shop Max or PBM Swirl Pot kit. Brand New, never been mounted just opened. 80.00 SOLD**
Brand New Parts Shop Max or PBM Oversized Rear Rotor kit/hardware. 350.00 OBO**
Dual Rear brake kit by George: 220.00 SOLD*
So what exactly is it? This bracket allows you to use 2 pairs of Z32 rear calipers for AWESOME stopping power. One pair of calipers gets plumbed up like normal and works off of the brake pedal. The other pair gets plumbed SEPARATELY to the hydraulic handbrake. No more weird pedal feel when pulling the e-brake and the footbrake! You now have a dedicated setup for the hydraulic handbrake.
I have two almost new HKS 740cc injectors will get pics @ request. 220.00 obo
OS Giken twin plate clutch for 13B rx7 FC will get pics @ request 320 obo. I would recommend replacing the hardware.
Also was thinking about getting rid of this: have an LS6 Longblock for sale or for trade : 56k miles sitting for a year and half possibly longer, in good running condition. 1700.00 OBO or trade for running s13 or anything else interesting. PM if interested please.
LS6 exhaust manifolds: 40.00
LS6 Stock Fuel Rail 40.00
LS6 Throttle Body DBW 40.00
LS6 FULL no cut Engine Harness 200.00 OBO
Looking to get cash for this stuff, but I would entertain any s14 SR stuff or s13 coupe stuff. So send me your options of stuff, or cash.
Stuff I need for the coupe:
SAFC
Electronic Boost Controller
Ceiling carpet.
Floor Carpet.
Middle console.
All the little plastic trim pieces.
S13 Coilovers.
Walbro or equivalent fuel pump.
Aero either silvia or pop ups. No ghetto ish!
Pop Up lights complete and working.
Silvia Headlights triple/dual/brick
SR Radiator
SR S14 Intercooler
SR Coolant Hoses/Rad.
S14 SR Intercooler piping
STOCK KA/SR shifter housing
S13 One piece driveshaft
S13 core support
Any interesting trades will be considered. Also this isn't a Lowballer thread, so feel the need to stfu about idiotically ridiculous offers. My time is important don't waste it. Thanks for looking and keep drifting fun.
I take paypal @Yam123yz@aol.com and CA$H
If you are feeling cunty and have nothing positive to bring to the thread then you can go sit on a flag pole pm me for the lube if you don't have any..Please, don't forget how easy it is to press the back button.
Old Dec 31, 2011 | 11:12 AM
JDM Chuki's Avatar
ill take those s14 ebay tails, how much would it be to ship to 33773?
Old Dec 31, 2011 | 04:12 PM
Jham's Avatar
i will get that maf. text me 813-516-3330
Old Jan 2, 2012 | 06:35 PM
BFTII40's Avatar
kahtsumoto
Price adjustments have been made. You buy now.
Old Jan 3, 2012 | 06:23 AM
JDMslider's Avatar
TTT for this man
Old Jan 3, 2012 | 08:12 AM
87redz13's Avatar
i got a bag of beef jerkey for the bov
Old Jan 5, 2012 | 09:06 AM
BFTII40's Avatar
kahtsumoto
Two bags and you str8. LOL. bumpbumpbump
Old Jan 5, 2012 | 02:16 PM
87redz13's Avatar
well give me a call when you r back in town
Old Jan 8, 2012 | 09:02 AM
BFTII40's Avatar
kahtsumoto
Added more parts for sale bump
Old Jan 9, 2012 | 08:17 AM
BFTII40's Avatar
kahtsumoto
Pics of longblock are up and revised a few things. TTT
Big Chris
Jun 2, 2009 05:56 PM
townidiot
For Sale/WTB Honda & Acura
4
Feb 15, 2008 02:26 PM
VWFREFF
For Sale/WTB Mitsubishi
29
Jul 16, 2005 09:57 PM
THE_ONE
Apr 26, 2004 06:06 AM
