View Full Version : Speakers.....
PreludeXTC
12-03-2002, 08:30 PM
ok in my 97 prelude i have stock speakers on the pioneer dehp8400 and they sound good the stock base and stuff sounds good but i know for a fact if i keep on playing it loud and stuff theyll pop pretty soon so i wanna get some better speakers.....but it has that acoustic feedback system in the prelude. is it a good idea to change the speakers??
lemme do a little reasearch and I'll get back to you.. just need to find the specifics
PreludeXTC
12-04-2002, 11:35 AM
ok lol :)
Joker
12-04-2002, 06:16 PM
yes you can change the speakers, you can pretty much put in what ever joo be wanting. just dont go to cheap with the jensen and the road gears.
The acoustic feedback system (afbs) uses small microphones in the rear speakers to listen to the sound and reduce distortion and improve sound clarity. At the heart of the system is a small black box which contains a small powered amplifier which needs to be removed to upgrade the system. So essentially get a new head unit and run new speakers straight from there and you won't have any problems
The deck is powered (no external amps). The speakers just need to be removed and replaced. You can get adapter harnesses from metra to use the factory speaker plugs. You can also just cut the ends off and put .110 and .205 ends on them. The car has 6.5 in. speakers up front and 6x9's in back (at least this is what the 97-01 Preludes have.)
PreludeXTC
12-05-2002, 08:01 PM
hmm vetty interesting.....why do you have to remove the factory amp? can you just connect the aftermarket speakers to the factory amp in back or no?
Joker
12-06-2002, 08:34 AM
in theory you could just use the same wires coming from the amp and retain the power for your speakers. but more than likely if you buy a quality deck the rms power will power your new speakers better than using the stock amp.
this
and I dont know how the factory amp and "acoustic feedback system" will feel about you adjsuing eq curves and the spears response to those
PreludeXTC
12-06-2002, 03:05 PM
this
hmm i guess ill just try it then...ill tell you all what happens...now if i could just find some good speakers for a good price lol
DANGERANGER
12-17-2002, 09:50 PM
HOW MUCH MONEY DO YOU WANT TO SPEND?I HAVE SOME BARELY USED SPEAKERS THAT MIGHT WORK.
PreludeXTC
12-17-2002, 11:29 PM
what kinds? how much?
DANGERANGER
12-17-2002, 11:45 PM
THEY ARE CLARION AND KENWOOD 6.5 AND 6X9S. I DO NOT REMEMBER WHICH IS WHICH THOUGH. BARELY USED.
Content Relevant URLs by
vBSEO 3.2.0 RC5
