FS:KA24DE parts on the low!!!
Old Sep 30, 2011 | 03:43 PM
lilbnort93's Avatar
Default FS:KA24DE parts on the low!!!
cleaning out the shop. lowballers welcome!!!
all items are KA24DE parts unless otherwise noted
KA24DE ecu - 30 bucks
S13 ka24de valve cover 25 bucks
ka24e valve cover 20 bucks
S14 stock radaitor (a bit bigger than s13) 40 bucks
Kade bare block 30 bucks.
single cam oil pan 15 bucks
dohc oil pan 15 bucks
power steering pump 20 bucks
AC compressor 40 bucks
4 new oem pistons on stock rods. 50 bucks
KAde good crank 50 bucks SOLD
lower timing cover with good working oil pump 30 bucks
Upper and lower timing cover powder coated white - 40 bucks.
crank pulley with bolt and washer 10 bucks
good kade starter 20 bucks
s14 cams with caps and cam gears for 40 bucks SOLD
s13 cams 20 bucks
full timing chain set 30 bucks
upper timing cover 15 bucks SOLD
AC bracket 15 bucks
Power steering bracket 15 bucks
stock kade injectors in rail with caps and fpr for 40 bucks SOLD
used arp headstuds for 40 bucks SOLD
s13 kade wiring harness good harness for 75 bucks everything looks to be there
Old Oct 1, 2011 | 10:38 AM
lilbnort93's Avatar
up
Old Oct 3, 2011 | 07:48 AM
lilbnort93's Avatar
Old Oct 3, 2011 | 07:51 AM
stockhfcrx's Avatar
pm me about rods and pistons?
Old Oct 3, 2011 | 08:10 AM
lilbnort93's Avatar
pm'd
Old Oct 3, 2011 | 04:51 PM
RodFarva's Avatar
Bump for a good seller.
Old Oct 4, 2011 | 12:35 PM
lilbnort93's Avatar
up
Old Oct 5, 2011 | 03:49 PM
lilbnort93's Avatar
Old Oct 6, 2011 | 03:11 AM
dwrec37's Avatar
bump.
Old Oct 7, 2011 | 05:25 AM
lilbnort93's Avatar
up
