B16a vs B16a2 differences in block?
Old Aug 2, 2011 | 05:53 PM
Brandon H.'s Avatar
Default B16a vs B16a2 differences in block?
So I have a 99 Si, and a B16a short block I wanna build for it. Would I run into any problems dropping a B16a block in my Em1? Stock ECU and harness. Will be a mild motor rebuild with ARP studs.
Whats the differences between blocks?
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Aug 4, 2011 | 04:49 PM
Brandon H.'s Avatar
Anybody
1999 Honda Civic Si
TR em1 crew #43
Old Aug 4, 2011 | 07:27 PM
88_Hatchy's Avatar
I'm cooler than you
There are no significant differences. The fan switch is in a different location. I'm not sure if the early B16 engines are equipped with a location for he knock sensor. I can check tomorrow.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Aug 5, 2011 | 04:32 AM
Brandon H.'s Avatar
Ok cool, so just the fan switch might be in a different spot, and possibly no knock sensor. Ill have the check to see if maybe there is a spot so I can drill/tap one.
That it?
1999 Honda Civic Si
TR em1 crew #43
Old Aug 5, 2011 | 11:06 AM
88_Hatchy's Avatar
I'm cooler than you
You should be able to use the thermostat housing of the B16A2 on the B16A so that the fan switch won't have to be changed.
crls057
For Sale/WTB Honda & Acura
Sep 8, 2006 08:31 PM
JDMjunkie
Aug 11, 2006 08:21 PM
civicman77
Apr 28, 2006 04:49 AM
ODB
Jan 2, 2006 08:47 AM
TSX24L
10
Sep 24, 2005 04:00 PM
