View Full Version : Ramcharger is fux0red
Iroc Joe
10-20-2002, 10:38 PM
This is my answer to Jeff's post about the Spirit. We shall go back and forth, trading stories of woe.
Well today I got the fuel pump replaced. Only took the removal of the bumper, trailer hitch (which required the sawzall on the last bolt) skid plate, tank straps and finally the tank. Then as I'm holding the clips for the feed and return lines to the pump, my father pulled the hoses. Full pressure (about 40 psi ??) right into my eyes. Yes, they still hurt. Dumped the fuel tank (not telling where) and cleaned out the tank with paper towels. You wouldn't believe how much shit was in there. Put the new assembly in the tank and put everything back together. Put a couple of gallons of gas in it, drove to the gas station and filled it up. Well after all that, it still won't run right.
Then we thought, hmmm this might be the cat. So I banged on it with a hammer and all sorts of shit flew out of the tailpipes. Minor improvement. I still think the timing is retarded like TIMMAAAAAAAY and I'll czech it with my timing light tomorrow when I pull the cat. Also I czeched the air cleaner and I think it's safe to assume nothing (not even air) was passing through it. However, running without the element showed little improvement. So in other words, today accomplished nothing. But I did break the oil sending unit while trying to loosen the distributer bolt. The distributor is being a cranky old whore and refuses to budge. Damnit.
So $300 later, the truck still wants to vibrate itself apart (violently I might add) under any acceleration.
mpbiv
10-20-2002, 10:42 PM
Sounds like much needed basic maintainence to me.
CrazyMoparGirl
10-21-2002, 12:37 AM
quit yer bitching
FearThe4Doors
10-21-2002, 02:46 AM
if the tank was that shitty.. did you change the filter and flush the fuel lines?
CrazyMoparGirl
10-21-2002, 08:54 AM
Injector cleaner? can't remember if it's injection or carb'd
mpbiv
10-21-2002, 10:53 AM
I would say EFI since he was replacing the pump in the tank.
How many stock vehicles do you know of with carbs and in tank electric fuel pumps :P
whore
10-21-2002, 11:06 AM
Mr Know It All And Pays Attention To Details! :p
CrazyMoparGirl
10-21-2002, 08:30 PM
Yeah well hey I got other things I'm focused on right now
mpbiv
10-21-2002, 08:39 PM
Like finding that P-body that got lost
Iroc Joe
10-21-2002, 09:15 PM
It's a '93 318, same as '94-'99 cept it's speed density.
Well, ran a compression check. 3, 5 and 7 are dead.
Looks like valve springs or possibly valves. Will yank valve cover to check accordingly.
CrazyMoparGirl
10-22-2002, 03:24 AM
Did you put a teaspoon of oil in the dead cylinders to see if the compression came up? If it does it's your rings.
whore
10-22-2002, 04:02 AM
are you gonna put the old fuel pump back in now, add the grime to the tank, and throw some dirt at the air cleaner since you know that's not the problem now?
Iroc Joe
10-22-2002, 09:31 PM
Indeed I did today....5 and 7 came up. Can't be rings, truck burns no oil and you can smell/see no oil coming out the exhaust.
My uncle brought up a good point, could be a head gasket or cracked head. Debating if I should go yank the head now because I'm bored and restless or wait until daylight and run a leak down test on them first. Either way, it has to come off.
Iroc Joe
10-22-2002, 09:32 PM
Already ahead of you :)
CrazyMoparGirl
10-22-2002, 10:18 PM
my exp has always been rings, my omni had a bad cylinder and it didnt smoke. My van had a bad cyinder and it didn't smoke, both were rings It's a loss of compression, therefore the oil is just enough to fill the gap and not enough to cause it to smoke. If you had a bad headgasket there would be h2o in you oil. As far as a cracked head, never had one or seen one on an engine. If it is a cracked head, might I suggest some magnum heads and misc amc valve train parts :D
Iroc Joe
10-22-2002, 10:25 PM
well it already has magnum heads, seeing as how it's a magnum 318. However, it is an excuse to get shitty with a rebuild :)
CrazyMoparGirl
10-22-2002, 11:53 PM
oh shit I keep forgetting the year of your truck. Got way too much on my mind with work. Trust me it isn't your heads. Just cause you don't see smoke doesn't mean there isn't a fire. Back to the head subject, might I suggest a set of R/T heads :D
CrazyMoparGirl
10-23-2002, 07:18 PM
straight from the service manual:
page 3-31 #8
If a cylinder is unusually low, pour a tablespoon of oil through the spark plug hole and repeat compression test. If the compression comes up after adding the oil, it appears that the cylinder's pisron ring or bore are damaged or worn. If the pressure remains low, the valves may not be seating properly (a valve job is needed) , or the head gasket may be blown near that cylinder. If the compression in any 2 adjacent cylinders is low, and if the addition of oil doesn't help the compression, there is probably leakage past the head gasket. Oil and coolant in the combustion chamber can result from this problem. There may be evidence of water droplets on the engine dipstick when a head gasket has blown.
So your headgasket at 5 could have blown causing a pressure leakage between 3 and 5 and 7 could have bad rings or bore. Since you seem to want to believe you have a blown headgasket.
Iroc Joe
10-30-2002, 08:46 PM
So my father says to me
I flat out don't believe there is no compression in those cylinders, I'm going to find my compression gauge. I said to him "well, I was standing there when Charlie ran the test"
So we proceed to run a check and find 160 across the board. Hmm, what the fuck. Must be fuel injectors says he. yanked the injectors from the manifold, and tested them. The three lame cylinders' injectors weren't spewing much fuel. Pulled them from the rail and found all sorts of shit clogging them up. Cleaned them out, replaced and viola. Truck runs beautifully.
Bastardized fuel injection :lol: :lol: :lol: :lol: :lol:
Oh well, now the injector o-rings are apparently old and worn so fuel pisses out onto the intake manifold.
Napa part # 2-12093 fuel injector service kit :D I have eight of them sitting on my desk and when I have time, I will re-ring them.
Funny thing is I paid $1.10 per "kit" at Napa. Jerry Ulm Dodge wanted $15 per "kit". Each kit contains two little rubber o-rings.
:doublebird: dealer :lol: :lol: :lol:
CrazyMoparGirl
10-30-2002, 09:54 PM
Well Hot Damn the REdNeck livith
Content Relevant URLs by
vBSEO 3.2.0 RC5
