91 SAAB 9000 non turbo to many problems to list
Old May 23, 2011 | 08:24 PM
SchassisofDOOM's Avatar
Angry 91 SAAB 9000 non turbo to many problems to list
OK I Have a 91 9000 first major problem is a cold start issue when i crank it up from sitting all night crank starts and dies if i unplug the maf and run it till it warms up will start and run fine after it heats up revs all the way to redline with or with out maf attached after heating when cold it just dies consently after warmed up car runs great
second problem is dash lights not working including gauge cluster cant figure it out not a fuse
dont want to just throw parts at it hoping someone on here has ran into some simaler issues with this pos
Old May 25, 2011 | 06:19 PM
Zman's Avatar
I gota Cheby
does it have a chevy motor in it, reason I ask is that this is the GM section
Only 1/4 mile track I know is Gandy Bridge
Old May 28, 2011 | 07:22 PM
J@meson's Avatar
Resident Ginger Kid...
GM owned SAAB... FYI
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old May 29, 2011 | 01:10 PM
Zman's Avatar
I gota Cheby
yes I know GM owns Saab, but I think as you can see he hasnt had a answer yet, so maybe its the wrong section. oh yes its a 1991, GM didnt own Saab back then. 1999 then totally in 2000
Old Jul 8, 2011 | 09:42 PM
jackjroadster's Avatar
Originally Posted by SchassisofDOOM
OK I Have a 91 9000 first major problem is a cold start issue when i crank it up from sitting all night crank starts and dies if i unplug the maf and run it till it warms up will start and run fine after it heats up revs all the way to redline with or with out maf attached after heating when cold it just dies consequently after warmed up car runs great
dont want to just throw Saab parts at it hoping someone on here has ran into some simaler issues with this pos
Does it stall without braking?I recommend checking the intake and AIC plumbing and see if there are cracks.Also you should have ABS so it would have no direct effect on the motor control, most especially if your car does not establize with running or when near idle.
saabsam
Dec 23, 2008 12:08 PM
saabsam
Nov 25, 2008 01:44 PM
kill3rrobot
WTB / For Sale Other Makes & Models
4
May 7, 2008 04:48 AM
