FS: Brand New Prosport "EVO" Series Digital Gauge set
Old Feb 2, 2011 | 06:33 PM
s132nr's Avatar
Default FS: Brand New Prosport "EVO" Series Digital Gauge set
As title says i have 3 of the latest gauges from Prosport. These are Brand new, just released from Prosport and the only dual color digital gauges availible. Red and blue.
Introducing the 4 time award wining, (SEMA show 2010) industry first, dual color digital gauge. This gauge has a Black bezel, Black case and is Blacked out when off. This one gauge can display either Red or Blue and is dimmable !
A 270° dial sweep provides quick one glance accuracy. Track tested and race proven these gauges use precision electric senders (Included) to keep hazardous fluids out of the passenger compartment.
All of our Evo Series gauges perform a dramatic opening ceremony with a full digital sweep each time the vehicle is turned on.
These gauges are very thin, perfect for tight mounting options
I Have a
1. Oil pressure with all accessories, (0-150 PSI includes: Sender, mounting hardware, decal and Instructions)
2. WIDEband Airfuel Gauge,
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9 is our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet.
Featuring a Dual color (Red or Blue) readout in the center of the gauge and a bar-graph syle LED's around the outside of the gauge for immediate reference to AFR.
0-5 volt output signal for data logging
3. Water temperature Gauge
with a 270° dial face and utilizing only top grade sending units these full sweep Digital electric gauges are durable, reliable, safe & easy to install. Monitor your engine temperature with more precision. Keep hazardous fluids out of the passenger compartment.
(80°-280°F includes 1/8" NPT Sender, Mounting hardware, Decals and Instructions)
Gauges new are 350$ plus shipping
$325 picked up. All gauges used for 2 days, Going another route again. Gauges come with all new original packaging and contents
I also have a Prosport Radiator hose adapter 34 mm for supra, sr20det, 34 Millimeters = 1 3/8"
15$
Image Gallery
Old Feb 3, 2011 | 09:37 AM
MikeyL513's Avatar
BOOSTIN
sell just the oil pressure gauge? pm me if yes.
Old Feb 3, 2011 | 05:11 PM
johnathan.ramirez's Avatar
uppp bump for ladd
Old Feb 3, 2011 | 05:36 PM
x8psycho8x's Avatar
if your willing to seperate the gauges that dude ^^ can buy the oil pressure gauge and i'd really like to try and get the coolant. I'm sure the wideband wouldn't be to hard to get rid of. just food for thought, worth a shot asking.
bump for you!
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Mar 10, 2011 | 09:52 PM
s132nr's Avatar
willing to seperate if i have buyers lined up, ttt
Old Mar 11, 2011 | 09:16 AM
MikeyL513's Avatar
BOOSTIN
pm me a price on the oil pressure and wideband. ill most likely just get the oil pres tho.
Old Mar 11, 2011 | 09:39 AM
TPNORTH's Avatar
pm me a price on the wideband i maybe interested
Old Mar 11, 2011 | 11:17 AM
s132nr's Avatar
selling wideband for 195$ and each gauge for 65$ which makes 325$ total
Old Mar 11, 2011 | 12:09 PM
x8psycho8x's Avatar
where you located and are you willing to ship?
95 eclipse rs - dd
Old Mar 11, 2011 | 02:12 PM
MikeyL513's Avatar
BOOSTIN
Where you located? ill grab that oil pres tonight
