ecu isnt getting power, please help!
Old Jan 25, 2011 | 10:48 PM
travishoward's Avatar
Default ecu isnt getting power, please help!
car is obd1 and so is ecu
my car was running perfectly fine, but my tranny was screwed and the car wasnt driveable, so i swapped another tranny in and now the car wont start
im not getting power to my ecu (i know this because the cel doesnt come on when the key is turned to the on position)
ive tried 3 different main relays, they all prime the fuel pump everytime
ive put my ecu in my buddies car and it drove perfect
ive checked all 3 main grounds (thermostat, tranny, and head) all good
ive checked and replaced my ecu fuse in the in-bay fusepanel
ive checked and replaced all my fuses in both the underdash and in-bay fuseboxes
ive changed the ACG fuse
made sure the harness plugs were all put in, all the way
ive even replaced the bulb for the cel in the cluster (incase it was just blown)
im still, not getting power to my ecu
car starts, then dies instantly
timing is correct, and dizzy is timed correctly and rebuilt with brand new parts (cap, rotor, coilpack)
new sparkplugs properly gapped
help? someone? i dont wanna have to drop 100 bucks to get neal sutton to my house..
are there any grounds ive missed? anything i should check?
thanks in advance!
- travis
Old Jan 26, 2011 | 10:21 AM
Old Feb 1, 2011 | 07:03 AM
integra's Avatar
90% grind 10% sleep
what kind of car?
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Feb 1, 2011 | 10:06 AM
wakeking48's Avatar
Yes!!!!
Hey everyone he fixed this about a week ago he had a loose plug under the dash he hooked up, also his battery was really dead so it would not show the cel, and his ignitor was bad so he swapped in out now the car runs great.
2001 King Ranch F.150 (sold)
1991 5.0 Ls mustang (sold)
1993 ls cx hatch (traded)
1995 b16 eg coupe (SOLD)
2007 Hyundai Tiburon (sold)
2006 Yamaha R6 (sold)
1995 jdm b20b integra (sold)
2006 Mitsubishi fp red evo (dd)
Old Feb 2, 2011 | 09:26 PM
jackjroadster's Avatar
Have you checked the timing belt? I just got the idea on Acura repair and tried it. Why don't you remove the spark plugs then perform a compression test. Try to post the compression readings after.
