obd1 swap questions
This is going in a '95 Integra GSR. I'm new to the obd1/hydro. I'm planning on either putting my ls/vtec or just get a ls swap and turbo or spray it. What axles would I need? Are all '94 up B-series axles the same? If I was to do the ls swap, is there any wiring changes? I had to add/move 4 wires when I did the vtec conversion in my Crx. However, I did run it for two weeks with the ls ecu and had no problems? I'm assuming I can keep the wiring the way it is?
Are all B-series shift linkage the same?
Is a obd1 distributor different from a obd2?
Thanks.
Thanks.
yeah an ls ecu will work fine. All 94+ integra abs axles are the same.
Gracie Barra Clearwater
