Fuel for wet Nitrous kit???
Old Dec 14, 2010 | 05:21 AM
Paul2281's Avatar
Default Fuel for wet Nitrous kit???
Where do you tap into to get the fuel for a wet nitrous kit....The only way I see is to cut into the fuel line or have a separate fuel tank or something.....
Old Dec 19, 2010 | 02:06 PM
eightwun3zfynest's Avatar
sleeper
ive seen some hook up to a splitter on the fuel rail,
Old Jan 4, 2011 | 08:45 PM
yoshi06's Avatar
cut fuel line between filter and rail and use a tee
Old Jan 16, 2011 | 02:54 PM
SlowCivicEx's Avatar
You have to have a fuel cell in your trunk. Make sure you get at least a 5 gallons. If you dont wanna spend the money on a fuel cell you can just use a red gas jug. Good luck!!
Old Jan 16, 2011 | 03:51 PM
SmokinS13SR20's Avatar
That ginger...
Pretty much this, but you need to make sure your fuel pump can push enough volume to supply fuel to the injectors and the nitrous solenoid.
Old Jan 16, 2011 | 05:37 PM
Paul2281's Avatar
What I found that will work is use the adapter that is used for the fuel pressure gauge on the fuel filter assmbly......Instead of putting the gauge there I can come off the 1/8"npt with a barbed nipple and run a line from there to the fuel solenoid...That elim. a couple of connections from possible leaks....I believe that will work huh....
Old Jan 16, 2011 | 10:24 PM
That ginger...
That doesn't seem like a bad idea at all.
Old Jan 17, 2011 | 04:33 AM
Paul2281's Avatar
Cool,cool....Thanks....
