View Full Version : Will these injectors work?
I have found a set of MP performance 52 injectors. I assume these are the super 60 injectors, part number 4532586
Can I run these injectors with my stage 2 CPU? I plan on doing the needed fuel upgrades.
What would I have to change? I have already installed a zener diode and a bleed valve on the wastegate.
FearThe4Doors
08-26-2002, 04:08 PM
you should be able to use them. You just might have to adjust your fuel pressure
flybyuin2.2
08-26-2002, 06:07 PM
the part# should be P5249452 the number you listed is 84-86 i believe also its not showing up in parts catalog :werd:
4sfed 4
08-27-2002, 08:47 AM
The P4532586 stamped injectors are indeed the Super 60 52 pph ones. The MP5249452 number given above is the Mopar Performance part number for the same injector. I believe the MP number represents a 4 pack of the injectors.
Is $75 a good deal for 4 new ones?
mpbiv
08-27-2002, 10:13 AM
If they are new in the box I'd say so, Relentless Performance carries 53pph ones for $150 new
4sfed 4
08-27-2002, 12:57 PM
Yes. New in the box that is a steal. Even if they are used (in good shape) that is still a good price.
Dealer cost is around $27 each.
whore
08-27-2002, 01:02 PM
hey larry. know any good electronic repair places that would be able to work on a digital camcorder?
4sfed 4
08-28-2002, 09:01 AM
Hmmm......
To be honest, any time Ive ever had an item like that with a problem, it has always been easier and cheaper to just buy a new one :(
whore
08-28-2002, 02:14 PM
cheaper to buy a new digital camcorder??? :o
Content Relevant URLs by
vBSEO 3.2.0 RC5
