B series in ef spindle question
Old Nov 10, 2010 | 07:03 PM
sovlisky's Avatar
Default B series in ef spindle question
I have a bent spindle in my ef that has a b20 in it I was looking to trade for sum new ones but not really sure which ones to use I've heard eg ones give you positive camber and since my car is droped and I have camber kit and it's maxed out the other way I figured this would get me about were i need to be any help would be apprciated thanks
Old Nov 10, 2010 | 07:06 PM
flatrex's Avatar
crx hatch sedan
Use DA integra parts
Old Nov 10, 2010 | 07:09 PM
sovlisky's Avatar
Could u tell me how to identify the spindles I have now and can I ask you why u recomend da spindles
Old Nov 11, 2010 | 06:35 AM
integra's Avatar
90% grind 10% sleep
i have a DA spindle but it has a bad bearing....20$ and its yours. If you bring the bearing with you,i will change it before you leave.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Nov 11, 2010 | 06:47 AM
flatrex's Avatar
crx hatch sedan
I recommend DA because they give you bigger brakes and are the closest to an ef as far as the suspension geometry. I'm not really sure how to identify them but there might be some letters and numbers stamped on them. Or you can spend the money and buy ef sir stuff or if your lucky you can find spindles from an ef sedan ex model you will get the bigger brakes with those aswell, they are just much harder to find than DA spindles.
Old Nov 11, 2010 | 07:52 AM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
The EF and Da knuckles...near where the upper ball joint goes through.....there are 2 threaded holes for the ball joint nut cover......thats how i identify them......i habve DA knuckles on my rex for years..no problems, and yes the bigger brakes are great
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Nov 11, 2010 | 05:31 PM
sovlisky's Avatar
Are the calipers and rotors interchangable between ef and da spindals cause I have brand new brakes on my car
Old Nov 11, 2010 | 05:53 PM
HondaHouse's Avatar
no they are not interchangable......ef have 9.2 or 9.3 inch rotors and Da have 10.1 ish.......da's have bigger brakes
Old Nov 11, 2010 | 05:58 PM
sovlisky's Avatar
Ok thank u sir now I need sum da spindles who wants to trade sum parts for a pair with good bearings perferably
Old Nov 12, 2010 | 04:33 AM
integra's Avatar
90% grind 10% sleep
I posted above..
