C clip eliminators and disc brake?
Old Oct 26, 2010 | 07:28 AM
500HPLX's Avatar
Default C clip eliminators and disc brake?
I have a 88 Fox and with the power I expect out of this turbo combo, seriously need to look at upgrading the rear end.
This is what I have in it now.
8.8 w/ 3.73 gears (likely going to 3.27's)
Auburn Pro Posi 31 spln
Ford Racing 31 spln 5 lug, Fox length axles
T/A cover
North Race Cars backing plates (allow you to keep stock Fox rear track width)
Cobra/Bullit rear brakes
What will work to eliminate the C clips and keep the brakes and stock width?
Old Oct 26, 2010 | 07:43 AM
Hurstmeister's Avatar
Do you already have disc's or are you asking for a stock width disc brake application?
As for C-Clip eliminators,.. they were designed to be used with drum brakes and prevent the axle from coming out of the tube in the event of an axle braking.
I've seen SN95 guys brake axles and never loose an axle. The caliper held the axle in place making the need for C-clip eliminators obsolete. So if you already have discs,.. you theoretically could remove the Eliminators with out fear.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Oct 26, 2010 | 08:56 AM
500HPLX's Avatar
Thanks Hurst.
The parts listed are what is currently on the car.
I know the Fox cars used eliminators with drums, but had never heard/saw what SN-95 guys were doing.
Guess I will leave it as is.
Old Oct 26, 2010 | 09:10 AM
PinappleXpress's Avatar
ever looked at switching to a 9"?
Old Oct 26, 2010 | 09:23 AM
GNs-r-slow's Avatar
Bondsman
No need if your not wanting to do gear changes at the track.
Old Oct 26, 2010 | 09:26 AM
GNs-r-slow's Avatar
Bondsman
Eliminators dont widen track with....I have Moser elim. with sn brakes on my build, stock width (Fox)
Old Oct 26, 2010 | 09:27 AM
tis true. but it dont seem like its a track car. toss the gear you want in it and go.
Old Oct 26, 2010 | 12:58 PM
GNs-r-slow's Avatar
Bondsman
Hurst
Eliminators were designed to hold in axles on a C-clip set up, has nothing to do with brake set up.
As far as the second part you posted, depending on how fast you go at the track, you are required to have them on your car, no matter what brakes you run to be legal, they are not obsolete.
10.99 or faster
The aftermarket axle requirement also extends to installing a C-clip eliminator kit in any rearend that uses a C-clip to retain the rear axle, such as the GM 10- and 12-bolts and the Ford 8.8-inch rearends. While the current NHRA axle rule does not include an SFI spec for axles, experienced axle manufacturers such as Summers Brothers, Mark Williams, Strange and others offer axles intended for this kind of abuse.
Old Oct 26, 2010 | 02:05 PM
8.8 is plenty strong. Properly set up it can take a car into the 7's.
3rd and 4th gen Fbody guys are using 8.8's instead of 9 inch or 12 bolts.
GM guys like them because the cars typically dyno 20 - 30HP more with an 8.8 vs a 9 inch. That and the simplicity of gear changes.
Hurst
Old Oct 26, 2010 | 02:47 PM
$hawn's Avatar
lives in a glass house
exactly. I have stock length axles, c-clip eliminators, and aerospace disk brakes.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
