How in the hell do I fix a broken nut inside the frame? And other things..
Old Oct 9, 2010 | 04:04 PM
Brandon H.'s Avatar
Default How in the hell do I fix a broken nut inside the frame? And other things..
Car=1999 Si
Ok so my motor mounts are shot, really shot. Found out the back motor mount under the intake isn't even bolted to the motor, the mount next to the AC compresser is completely broken away, and the under the tranny to the frame rail has both bolt holes stripped. There is nothing to bolt the damn mount to!!
Questions
1. How in the hell do I get the bolt for the engine mount under the intake in there? I can hardly see it, under and over the engine. I am not pulling the intake.
2. The mount on the tranny side on the bottom, what should I do to fix this? The nuts are completly broken inside the frame, and both bolts are half undone.
3. I think my axle shaft on the driver side is bad, grease in the wheel and when I drive I hear popping, the faster I drive (no matter RPM), the faster the clicking. What all needs replaced when doing this?
4. Whenever I just get in my car and got to leave somewhere, and I cut the wheel hard to the left as I am backing out, there is a loud pop I can feel through the wheel, is that the axle shaft doing that? I didn't see anything out of place other then that when I was under there.
Pics..
Homemade ramps
Stripped bolt..
Busted mount..
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Oct 9, 2010 | 05:29 PM
Luis#15's Avatar
if u need help lmk i can give u hand anytime
FOR YOUR MECHANICAL NEEDS GIVE ME A CALL OR TXT (813) 531-1387 (MOTOR/TRANNY SWAPS,ETC)
Old Oct 9, 2010 | 05:35 PM
integra's Avatar
90% grind 10% sleep
ill buy that front trans mount that you broke.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Oct 10, 2010 | 08:55 AM
Brandon H.'s Avatar
Anyone? I don't see how its posible to change that rear mount without pulling the intake mani. How is this done?
1999 Honda Civic Si
TR em1 crew #43
Old Oct 10, 2010 | 11:10 AM
Importracer13's Avatar
99CivicSi
it can be done dont get me wrong its a bitch but i know it u take intake off and disconnect the dizzy and move all the wires ouuta the way u can some wut get to it from the pass. side but other than that try comin from under neath
I <3 BOOST
EM1 Crew Member #16
OVERDOSE CUSTOMS FROM BASIC MAINTENCE TO ENGINE SWAPS, CAR AUDIO , PAINT AND BODY
Honda,Toyota, Nissan,Ford,Chevy Dodge, Everything
14525 62nd streeet north Unit 3&4
Clearwater FL 33760
CALL OR TXT 727 465 8295
Iggy Azeala
Old Oct 10, 2010 | 11:51 AM
rangcrx's Avatar
engine building &amp;amp;amp;best
its not to hard you dont have to take of the manifold,you just have to take your time its 14mm bolts if you have airtools its Easier,then get up under the car...as for your Tq mounts buy new ones or better yet baller buy these..
Civic EG EK Engine Billet Motor Torque Mount B20 D16: eBay Motors (item 110584757382 end time Oct-10-10 22:53:27 PDT)
i love AUTOZONE
Old Oct 10, 2010 | 01:09 PM
Rogue's Avatar
Used Register
Could also get the Energy Suspension engine/torque mount kit.
Amazon.com: Energy Suspension 16.1106G Black Hyper-Flex Motor Mount Insert: Automotive
Amazon.com: Energy Suspension 16.1106R Red Hyper-Flex Motor Mount Insert: Automotive
Old Oct 10, 2010 | 02:03 PM
Brandon H.'s Avatar
Ok I will give that a shot.
I was going to use those engine mount iserts, but never got any feedback if they were any good in a previous thread. I think I will still get them.
As for the clicking noises, you guys think its the axle shaft doing that. Is that normaly jsut the CV part?
1999 Honda Civic Si
TR em1 crew #43
Old Oct 10, 2010 | 03:14 PM
Rogue's Avatar
Used Register
I'm going to find out if the inserts are any good in a week or so. D-side torque mount is completely torn... my friend said the Energy Suspension set can still be used on it to fix it. Everything I've heard about them is that the car will shake more from the engine vibrations, being that the Energy Suspension inserts are made of a stiffer material than OEM.
Old Oct 14, 2010 | 09:05 PM
Rogue's Avatar
Used Register
So I got my Energy Suspension inserts today. I'll probably install them in this weekend.
Reading up on them a little bit, I see people mention that it's a good idea to use long/thin bolts in place of the plastic zip ties included with the inserts. I'm going to get stainless bolts, looks like a #8 fits perfectly.
