Discovery Learning, 94GT suspension
Old Aug 8, 2010 | 03:56 PM
Exekious's Avatar
ESWAT Imperator
Default Discovery Learning, 94GT suspension
So I discovered why my 94 GT vert bottoms out and scrapes. I had thought that my springs were too extreme for the car, but I was wrong. The springs are Steeda Sport Springs 555-8200 which seam to be a really nice springs. They drop the car just 1 - 1.25 inches which is normal to me. I thought they were at least 2" drop springs.
Instead it seems the K member itself is not hitting the car, but some poorly made k-member brace is the culpret. See the picture below, it looks pretty banged up. It sits about 2 inches lower then the rest of the car and the MM C/C kit is incorrectly installed (missing a spacer on each side).
The shocks are in decent shape, but I will just replace them with some newer mach1 tokico shocks that I have. I plan to keep the steeda springs and remove the k-brace. I'll order a new one to replace it.
The other, minor issue, is the tire size. I have 245/40/17 tires, but the OEM size is 245/45/17 which is a slightly higher side wall.
The other thing I learned is that my Momo rims are 17x8 and I would say the offset is better suited toward a front driving car. Someone put 5mm spacers to help with this matter, but they sit s bit inboard for my taste though I like the design.
Questions.
Do you think I should keep the Steeda Sport Springs or use the 04 Mach1 Springs?
What sort of brace would be a good replacement without costing to much. I saw one on Maximum Motorsports website for $90 new.
Old Aug 8, 2010 | 04:38 PM
harold harper's Avatar
h9
that is the extra brace they put on the vert cars.hard tops don"t have them.i would install subframe conecters.it will make a big improvement for your car.
Old Aug 9, 2010 | 02:25 AM
OldMan's Avatar
Donut Killer
I vote for, "keep the Steeda Sport Springs", but it is your car....
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Aug 9, 2010 | 10:37 AM
Exekious's Avatar
ESWAT Imperator
I called maximum motorsports today and they said they would prefer the Mach1 suspension over the current setup.
They also told me that I can replace the stock k-member brace with their piece and it will do the same thing. They also recommended a set of subframe connectors.
They recommended, new Isolators and pinion snubber for the back shocks if I stick with the steedas.
Old Aug 10, 2010 | 05:19 PM
Mars_302's Avatar
Race Photographer
well id make sure someone didnt cut a coil to make it lower. Plus sometimes they drop more than advertised
Old Aug 14, 2010 | 07:10 AM
Exekious's Avatar
ESWAT Imperator
I checked the Steeda spring and it wasn't cut. I decided to stick with them to make my life a little easier. I'm just swapping shocks and I will buy a new brace that sits flush. I hope that will correct the scrapping.
Finished installing the tokico shocks and it really makes a nice difference in ride quality. My car isn't bottoming out anymore. I guess the shocks were shot.
Now I just need to order a new 4 pt brace.
