View Full Version : 808.. you need to be on right now!
FearThe4Doors
07-20-2002, 03:09 AM
i was out checking my valves/springs and i think i may have a problem.. but it seems kinda like a too soft spring.. not a stuck valve.. dammit, come home!
rb70383
07-20-2002, 05:25 AM
Which one? A weak spring can also do it. If excessively weak it can allow the valve to stay open longer by not allowing the rocker to follow the cam lobe, it would get worse with rpms. Hence the compression during cranking speeds. Since the valve is lagging the cam (not following) Duh! it would allow the mixture to escape. Keep us posted. Sorry I wasn't on. :(
BTW I or E valve?
FearThe4Doors
07-20-2002, 12:18 PM
#4 exhaust. When i tap it with the hammer is just seems... "soft".. more springy as others.
What you say makes sense.. but wouldnt it make a backfire noise or anything out the pipe?
CrazyMoparGirl
07-20-2002, 03:17 PM
808 is currently sleeping and will wake up at approximatly 6pm EST thank you and have a nice day :D
FearThe4Doors
07-20-2002, 04:21 PM
i talked with my pa about it.. he agreed.. and since its the exhaust, it would be like giving it a LOT of overlap on that cyl. Rob it of tons of power he says. which fits what I thought all along... the cyl IS working, just not very hard.
Hmm... how did I get a county worker in there? :lol:
mpbiv
07-20-2002, 07:08 PM
Glad to hear you might have the situation solved :)
FearThe4Doors
07-21-2002, 12:59 AM
not yet..
CrazyMoparGirl
07-21-2002, 09:11 PM
is it yet , yet?
mpbiv
07-21-2002, 10:11 PM
Originally posted by "FearThe4Doors"
not yet..
"[/siz]"
Anyways I think you have checked just about every other posibility already, so nonetheless, good luck :)
FearThe4Doors
07-21-2002, 10:55 PM
yup, i have. I will change this spring then put it all together and try again.
CrazyMoparGirl
07-21-2002, 11:04 PM
spring pwn you
FearThe4Doors
07-21-2002, 11:14 PM
looks like i'll have to do all the springs... he had S60 springs on it and i should probably switch back to regular springs since it takes a lot of power to push them. Besides, i dont have an extra S60 spring laying around.
CrazyMoparGirl
07-21-2002, 11:16 PM
I hope you get the car fixed by Aug23rd.
FearThe4Doors
07-21-2002, 11:38 PM
me too... :(
FearThe4Doors
i need to talk to you & 808 sometime about the omni. (not glh)
CrazyMoparGirl
07-22-2002, 01:05 AM
you got our phone number, 808 will be home soon so call, it;s easier than typing
FearThe4Doors
07-22-2002, 01:08 AM
bah, my weekend minutes are over now!
rb70383
07-22-2002, 06:35 AM
That is kinda of contradictory. In that a weak S60 spring could have weakened to the level of a "stock" spring. Meaning if you put all stock springs in there it MIGHT NOT fix it. It can but....ya never know. The only way I could easyly see it fixing it was if you had a wild cam. High lift long duration. Then a stock tension/weakened spring would "jump" off the lobe causing the problem. I would go ahead and try it, I hope it works, but I always hope for the best, expect the worst. See if you can test that dead spring against a stock one. I am not sure that the calibrated hammer swing test would be accurate engough but fuck it its worth a shot. Just something for you to think about. :dunno: Worst case I'll help ya when we get down there. :(
BIG_Truck_Driver
07-23-2002, 06:34 PM
FearThe4Doors
feckin copycats
CrazyMoparGirl
07-28-2002, 11:25 PM
copy who?
FearThe4Doors
07-29-2002, 02:58 AM
copy pussy
CrazyMoparGirl
07-29-2002, 10:03 PM
You have a pussy? I always thought you were a Pussy :D
rb70383
07-29-2002, 10:07 PM
yip the cats meow. :lol:
FearThe4Doors
07-30-2002, 04:16 AM
i'm allergic to pussy actually
rb70383
07-30-2002, 04:34 AM
I am not surprised
CrazyMoparGirl
07-30-2002, 10:42 AM
Thta explains the SHeep
Content Relevant URLs by
vBSEO 3.2.0 RC5
