Need some help wiring Cruise Control with aftermarket steering wheel - S14
I am trying to make my cruise control work with my Nardi wheel, but need some help. The cable and everything was never removed just the wiring behind the stock steering wheel. I still have the original buttons and the red,red,yellow,blue pigtail that is attached to it. What do I wire these to? I have a brown male plug and a yellow male plug behind the column that are not connected and was guessing these are involved.
Any help?
Any help?
surprisingly, the infamous blackzenki had a pretty good setup on his car. he had buttons on the steering column cover under the steering column.
Nissan North America - Canton
Blackzenki's setup was done through this write-up...
240SX Steering Wheel Swap towards the bottom.
I gotta say, that's pretty slick.
Yes I have read that numerous times, but just need to know what harness to connect the button to.
Pretty much where are the second set of wires here:
If you decide to use the buttons that are attached to the wheel, you'll need to extract the harness from the wheel. For temporary use, I setup the harness to use the factory buttons. If you look at the diagram, you'll see the color combinations that you'll need. I removed the harness from the back of the "spiral" and spliced it into the harness that attaches to the buttons.
Button harness to "spiral" harness
Red -> Brown
Blue -> Green
Yellow -> Blue
Red -> Brown
Blue -> Green
Yellow -> Blue
Inmates can receive phone calls during certain hours. I'm sure he'd be flattered.
I need the plug with the brown, green, blue what connects to the yellow airbag plug with all the greens. Anyone that ditched their stock wheel and cruise have one?
Pictured below:
http://importnut.net/240pics/steerin...eharness01.JPG
Pictured below:
