2g GST Rear lower control arms the same?
Old Mar 31, 2010 | 08:25 AM
wishiwasfast's Avatar
Default 2g GST Rear lower control arms the same?
So I just finished the install of my Prothane Total Kit. All the suspension arms, knuckes are all stamped with either L or R, for there respective sides. All except the rear lower control arms. Is there a difference in which side I install them on or no?
Here's a pic for reference:
Its the one outlines in red or the number 6, the swaybar mounts to it.
Old Mar 31, 2010 | 11:35 AM
CODE4's Avatar
Tig Welder/Fabricator
They have the same part number, so I assume they are interchangeable.
TIG Welder & Fabricator
Old Mar 31, 2010 | 01:43 PM
Ok, thats what I found out so thanks for re-assuring me..
Old Mar 31, 2010 | 06:52 PM
omgosh's Avatar
Did the prothane kit come with bushings for that arm? My Energy Suspension kit didnt..
Old Mar 31, 2010 | 07:14 PM
yep. the only bushings not replaced were the ones on the front, on the curved bar.
Old Mar 31, 2010 | 07:25 PM
omgosh's Avatar
Damn I was wondering why the prothane kit was like $40 more lol. Wonder if I can just get those separate.
Old Mar 31, 2010 | 07:33 PM
You would have to buy the rear kit I think. But call them, they sent me a half a bushing that was missing from my kit for free, next business day shipping too.
Old Mar 31, 2010 | 08:44 PM
CODE4's Avatar
Prothane does include more bushings, hence the cost of course. Most of the bushings can be installed by hand as they are two pieces as opposed to needing a press. Still need to burn/cut/press out the OEM ones however.
The compression control arm up front (C-shape) retains its rubber as it needs the deflection during its range of movement.
Old Apr 1, 2010 | 09:02 AM
chillllll's Avatar
11 second club
^ genius
10 sec street truck...
Old Apr 1, 2010 | 09:56 AM
omgosh's Avatar
Good info. I was kinda dissapointed no one makes bushings for that curved arm.
As for installing them...no press is required. It would make it easier though. And burning is a waste of time. All you do to remove them is drill through the rubber in a circle from both sides. Then the metal part should fall out. Then take a reciprocating saw and cut through the sleeve in two spots. If it hasn't fallen out by now take a hammer/chisel and pound it out. Then you can press it in with liberal amounts of grease and a table vice. You can use a big socket on the back side so the bushing has a place to go instead of getting squished by the vice.
