View Full Version : Time for head
FearThe4Doors
06-06-2002, 09:30 PM
Yep, I think i'll finally go out and start on the head swap. I wont get the head off tonite because i dont have the 12pt socket for the ARP bolts, but i'll get all the little shit pulled off and ready for tomorrow. Maybe if i dig around in the toolbox i'll find a socket. I dont know half of what dad has.
CrazyMoparGirl
06-06-2002, 09:46 PM
And here I thought this related to Joe cumming back into town, pun intended
FearThe4Doors
06-08-2002, 03:22 PM
Ok, i got the head off.. no, i didnt start till today.. lol. It's still laying on the block, but all is disconnected. I just dont like having the block sit open for a day or two. I ordered one of those Fel Pro Head Shim things b/c my chambers are only at 50cc. And with a 2.5 that's a little on the high compression side. That will be here on Mon, then I'll put it all together. Tomorrow i'll probably bring the head in and switch all the manifolding.
FearThe4Doors
06-11-2002, 03:52 PM
This is an eye orgasm for me
FearThe4Doors
06-11-2002, 03:53 PM
This is what dreams are made of
FearThe4Doors
and what shatters riceboys
leadfootedfool
06-11-2002, 04:50 PM
Do you have your stock wastegate hooked up along with your blow off valve??
FearThe4Doors
06-11-2002, 05:12 PM
you mean using the same vacuum line?
CrazyMoparGirl
06-11-2002, 09:18 PM
well, 808 just got out of doing his "job" tonight :D
leadfootedfool
06-11-2002, 11:02 PM
I mean using the two together, not necessarily same vacuum line.
mpbiv
06-11-2002, 11:14 PM
Even though that question is not directed towards me, I am confused. Wastegate controls the speed of the turbo by allowing gas to bypass the exhaust turbine. The BOV is too help prolong the life of the compressor by letting out excess boost when the TB closes? You need to have a wastegate but a BOV is optional. You cannot substitute a BOV for a wastegate to control boost, thats what I understood, and the use of both is conventional.
leadfootedfool
06-11-2002, 11:42 PM
Blow off valve is a wastegate.
mpbiv
06-11-2002, 11:51 PM
:? Does not compute Will Robinson
Yeah sort of but I was under the impression that wastegate is a term reserved for a device on the exhuast side?
Would there be any reason not to use both?
FearThe4Doors
06-12-2002, 01:38 AM
LOL, i'm confused now too. The wastegate is like a trap door in the turbine housing (exhaust side) that opens and allows exhaust gas to bypass the turbine wheel, regulating the amount of boost the compressor side makes. A BOV is a valve that is between the turbo and the throttle body that when the TB slams shut (between shifts usually) yet the turbo is still cranking out boost. Instead of a big pressure spike bouncing off the TB and hitting the turbo... not good for the turbo, and slows it down big time which makes it have to spool back up for the next gear.... this valve opens and bleeds off the pressure. True, you do not NEED a BOV.. and ive never heard of anyone controlling boost with a BOV. It would have to flow TONS of air, and meanwhile the turbo would be spinning like mad and be way out of map.
So in reply to the question... i have both a wastegate and bov. Both are hooked up to seperate vacuum lines into seperate barbs on my vacuum manifold. Its not as critical to have them isolated from each other. You definatly want to keep the FPR(s) and MAP with their own line though.
FearThe4Doors
06-15-2002, 03:22 PM
ported head & ported 2-pc intake & ported Peters exh manifold installed - check
0.20" head spacer installed - check
52mm tb - check
cam installed - check
adj cam gear - check
timing belt back on - check
dist back in - check
vacuum lines hooked up - check
3/8" fuel return installed and hooked up - check
exhaust hooked up - check
oil changed - check
Still on the list:
Need two more 3" mack daddy IC pipe hose clamps
need to make my new intake piping hook up to the filter
put together a valve cover breather system
start engine
CrazyMoparGirl
06-15-2002, 11:16 PM
get to work, I want the car done when I get to Fl Mon night :D need to go for a test drive.
FearThe4Doors
06-15-2002, 11:19 PM
it just might be running then. But not nearly tuned
Content Relevant URLs by
vBSEO 3.2.0 RC5
