so wheel spacers?
Old Mar 13, 2010 | 05:03 PM
ardalan1122's Avatar
certified G
Default so wheel spacers?
if wheel spacers have become a consideration with the wheel setup, would it be safe to throw them onto the stock wheel studs, or should extended studs be replaced?
im looking at maybe a 10mm and a bit bigger for the rear
Old Mar 13, 2010 | 06:09 PM
Epstein's Avatar
Retired
You can generally do 5mm on stock studs. It depends on the wheel design. Most definitely, you're not getting away with 10mm+ on stock studs, though.
Old Mar 13, 2010 | 06:35 PM
elitist's Avatar
TR Balla Donor Supreme
Get hubcentric spacer adaptors. I think I have a set of 15mm ones here $40 and they're yours.
Old Mar 14, 2010 | 05:37 AM
poultry180sx's Avatar
i have 7mm on my s13, just did the 5 lug swap and threw them on there. if not hub centric your steering wheel will shake at about 70mph
Old Mar 14, 2010 | 08:31 AM
burgy240's Avatar
Offset-----Less is MORE!!
If you are running spacers you NEED the spacers with their own studs and do NOT run extended studs with slip on spacers....
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
Old Mar 14, 2010 | 08:45 AM
elitist's Avatar
^aka spacer adaptors
Old Mar 14, 2010 | 06:08 PM
burgy240's Avatar
^ You and I know that, but not everyone else does...
Old Mar 14, 2010 | 11:28 PM
S13Trav's Avatar
whats wrong with slip on spacers.. Jw, it seems like 5-10mm would be fine(with 35-45mm extended studs though)
1UZ!!!!
Old Mar 15, 2010 | 02:22 AM
Epstein's Avatar
Retired
Not sure I agree here. There's nothing wrong with running extended studs and 10-15mm spacers. I agree, though, if you're going 25+.
Old Mar 15, 2010 | 06:26 AM
burgy240's Avatar
I just don't like anything slip on, and especially if its 15mm or more?
