HELP: KA Oil Pressure Sender Port Troubles!
Old Feb 16, 2010 | 10:41 AM
chome's Avatar
Will sleep for food.
Default HELP: KA Oil Pressure Sender Port Troubles!
I was doing an oil change since I am scheduled for an autocross for the weekend and I noticed that the "T" fitting installed on my oil pressure sender port was starting to leak.
As I loosened that up, the fitting connected to the port on the block took off a little bit of material and threads from the port with it. Now it wont thread back in for me to reinstall the "T" fitting since it wont thread in and I cant close that port for me to refill the car with oil.
What I am asking is, how can I fix this? What options do I have? If anyone can help that would be really appreciated because I really need the car back before Saturday since I am scheduled for two event days.
Old Feb 16, 2010 | 11:02 AM
Epstein's Avatar
Retired
So you stripped the threaded hole in the oil filter housing? Why do you have a T there?
Old Feb 16, 2010 | 11:04 AM
chome's Avatar
No not the oil filter house, the oil pressure sensor port right next to it.
I have a "T" there because that is what is supplied with the JGS kit for the turbo oil feed.
Old Feb 16, 2010 | 11:08 AM
Super Coupe's Avatar
Old school TR member
^ You can just buy a new one. I believe I have one, I would trade it for that z32 pigtail if you pick up.
I wouldnt try and rig something that supplies my motor and turbo with oil.
It will be a huge disaster when it fails.
Old Feb 16, 2010 | 11:11 AM
chome's Avatar
I can buy a new what?
The sensor is fine, the threads where the sensor connect to are what is messed up.
Old Feb 16, 2010 | 11:14 AM
Let me try and clean this up.
The piece the oil filter connects to had a plugged port on it which you tapped into for your oil supply for your turbo.
That was leaking and now the threads are stripped.
Is that correct?
The whole assembly that the oil filter connects to comes off of the block if I recall. You can just replace that and avoid all problems or re thread it but you would spend more buying the correct tools.
Is this a KA?
Old Feb 16, 2010 | 11:17 AM
chome's Avatar
Alright the oil filter has nothing to do with what Im having trouble with. That is working perfectly fine.
Next to the oil filter is a port where the oil pressure sensor bolts onto. That port has the threads messed up and I cant bolt my sensor back on to bolt it shut. That is the problem I am having.
So I am asking how I can repair that.
Old Feb 16, 2010 | 11:20 AM
I get that. There is an assembly that bolts to the block you can just replace that, or just re thread.
Go look at it and you will see what I am talking about.
Old Feb 16, 2010 | 11:29 AM
chome's Avatar
Just went out and could not see a way that it could be unbolted and replaced. Do you have a picture or something that could better explain?
Old Feb 16, 2010 | 11:41 AM
LongFellow's Avatar
Please hold...
NISSAN 240SX KA24DE OIL FILTER BLOCK PICKUP WITH BOLTS : eBay Motors (item 220357888467 end time Mar-04-10 10:33:00 PST)
Team White Car 2010
